Cam question to avoid reversion >
Old 10-17-2018 | 08:11 PM
Default Cam question to avoid reversion
what am I looking for as far as cam specs to avoid reversion? Small block Chevy if it matters. I know you want minimal overlap but that is not listed on cam specs that I can tell. Just trying to avoid problems.
Alwhite00 is offline
Old 10-18-2018 | 12:59 AM
Overlap calculator
Camshaft Overlap Calculator - Wallace Racing
Griff is offline
Old 10-18-2018 | 04:40 AM
Originally Posted by Griff
thanks. What’s a good number with wet thru hull exhaust?
Old 10-18-2018 | 09:25 AM
I allso asked this question while a go. Answear was comp xm262 is max with stock manifods. I used comp xe262 automotive version with 110 lobe. Made 380hp 5200rpm, 442lb ft 3700rpm at flywheel, with pocket ported 997 cast Iron heads. Cr 9.5.
JaniH is offline
Old 10-18-2018 | 09:48 AM
LS1
Check PM's.
LS1 is offline
Old 10-18-2018 | 10:34 AM
With a Crower Hyd roller I'm at 221/230 @ .050" , 114 LSA with no reversion on stock exhaust manifolds/elbows with 4" thru hull exhaust. This is near the limit. Beyond that I'd likely need to dump the water further aft.
Trash is offline
