LSA Engine Open Cooling? >
Old 10-19-2018 | 07:22 AM
Originally Posted by LS1
I had a customer with a twin LSA application and we made some closed cooling tanks for him. PM me if you need any assistance. I still have some data and drawings that might help.
Dude thats NICE!
Keith Atlanta is offline
Old 10-19-2018 | 08:49 AM
I haven't looked but i would think Mrcool would also have stuff for the LS. Hardin Marine does.
Wildman_grafix is offline
Old 10-19-2018 | 10:01 AM
$15k for a complete LT4 from GMPP. Relatively cheap compared to marine stuff.
hogie roll is offline
Old 10-19-2018 | 10:06 AM
15x
The Motor is from GM Performance, every motor they list states "Not for Marine Use". As far as I can find out, they do that due to the extreme use & or extended WOT. So the 2 year warranty they provide would not be honored obviously.
The GM Marine engine they list online is identical with the smaller/lower less desirable upper intercooler from the CTV-S.
15x is offline
Old 10-19-2018 | 11:17 AM
BUP
coming to market totally cleanable as everything is removable and put back together. No temp changes thru sections of the cooler itself because there is NO TONs of solder. . No seems to break or leak - no rolled metal with soldered
end caps and so forth. 10 times the quality at basically the same price. Even when an engine lets go - totally taken apart and totally cleanable. No more throw away oil coolers and the same for the heat exchangers. The Heat exchangers are the same but of course larger is diameter and length than the oil cooler shown so just picture this as larger in size.
BUP is offline
Old 10-19-2018 | 12:05 PM
15x
Looks great, Where do you have them available? website?
15x is offline
Old 10-19-2018 | 03:36 PM
BUP
Next month - I am trying to data base the sizes of coolers and heat exchangers so I can cross reference from app to app. Not easy to do so that is talking alot of my time doing so.
BUP is offline
Old 10-22-2018 | 03:02 PM
So the 6.2L SC motor here isn't provided by GM? I have been wondering as it seems like this would be a nice replacement for my 500EFI motors. Less weight, closed cooling and MORE room.
GM Marine Engines GM Powertrain Marine
i was going to go this route on my old boat. was impossible to get a answer from GM about it. none of the local GM dealers or area rep had no idea either
id honestly just get a iron block 6.0 and go that way with some hard anodized heads
LTZCrew is offline
Old 11-17-2018 | 04:00 PM
15x
Do you have any of your heat exchangers available yet?
15x is offline
Old 11-19-2018 | 07:49 PM
BUP
Sorry I missed this. I have some oil coolers in currently. I kind of messed up my timeframes here because I am working on cool fuels for Merc and Volvo with the same engineers here. I should have some heat exchangers coming in soon. My other delay is still making the list for crossovers per the OEM coolers and heat exchangers. That is very time consuming alone. For the past 2 weeks I got hammered with winterizations because our lows last week was 4 days straight in the 20 s. I am trying to catch up with this. THANKS for asking and your time
BUP is offline
