Preparing cylinder heads for marine application
Subscribepayuppsucker
close
- Join DateAug 2012
- LocationCollierville, TN and Pickwick Lake
Liked:405 Times in 172 Posts
Quote:
The guides are Manganese Bronze and the seat are also Powder Metal which gives me good bones to start with.
I've just purchased a Rottler 3 angle cutting tool I'm not sure what valve seat width we will have until I cut a test piece, but I think I'm going to shoot for 5% of the valve diameter. We do have engine builders here in Nova Scotia but they are more reman stock engines, plus I like to keep as much work inhouse as I can and learn from the process. Thanks for all the pointers to date
I'd suggest contacting adk61 here on OSO. Top notch marine engine guy up in your neck of the woods.Originally Posted by Camalot
The heads are Flotek I've used on street engines before and been happy with them, sure they are not high end name brand heads but the casting are good and they use good components. Part of my business is a small but skilled engineering facility. We have no problem doing the machining work but Like you have pointed out we do lack knowledge between street and marine.The guides are Manganese Bronze and the seat are also Powder Metal which gives me good bones to start with.
A&j automotive Alyn Armstrong in Kingston NS has done some marine engines as well as Sussex engines in NB
Quote:
The Mercury Manual for high performance big blocks calls for a seat width of 1/32"-1/16" for intakes and 1/16"-3/32" for exhaust.Originally Posted by Camalot
I've been trying to find a valve seat face ratio but can't find one anywhere.
Ive always cut my seat widths to .040 on intake , .060 Exhaust . I also hit them real lightly with a lap stick and fine compound.
The powdered metal seats when cut that narrow with a dead pilot cutter , tends to not have real sharp defined angles .
With the good powdered metal seats they will spread .010 to .015 each after a few hours hard running , and seat in very well.
Quote:
The heads are not going to be the same off shelf heads as cars/trucks. merc sets them up for marine use, casting is the same sure... not the rest.Originally Posted by Ryan00TJ
Fully understand why you want the above in a big hp endurance marine build. Where is the line that it becomes mandatory? Look how many hours on stock 454/502 mpi and 496 setups. These are stock GM heads, same as in auto use.
ICDEDPPL
close
- Join DateJun 2009
- LocationChicago
Liked:6,484 Times in 1,952 Posts
I wonder if it`s different with closed cooling vs. raw water. First one, the block stays cold and doesn`t grow with the rest of the internals. (need larger clearances)
The other is closer to a auto application as the coolant gets hot and block expands with internals?
I have no idea what temps closed cooling runs. Does it get up to automotive temps (180*+?)
Probably makes some difference, I think closed cooling runs 145-150 if I recall, I see 110 most... so it may play a role but I think a tad loose .0017.0020 still would be wise
getrdunn
close
- Join DateFeb 2009
- LocationNW Michigan
Liked:1,515 Times in 824 Posts
Originally Posted by ICDEDPPL
I wonder if it`s different with closed cooling vs. raw water. First one, the block stays cold and doesn`t grow with the rest of the internals. (need larger clearances)The other is closer to a auto application as the coolant gets hot and block expands with internals?
That's a good point. I'm just guessing as well but you'd think the closed cooling temps would be very similar to auto. Might be completely different clearances, specs, etc all together.
underpsi68
close
- Join DateOct 2012
Liked:541 Times in 324 Posts
My 496 has a 160 thermostat and the oil runs 200-210 at steady 3500rpm cruise.
