9 pin efi wiring >
9 pin efi wiring
9 pin efi wiring
Old 12-09-2018 | 06:03 PM
Tinkerer's Avatar
Don't you want to tie in in front of the neutral start switch.
If you tie in at the engine you could accidentally start the engine with it in gear.
Tinkerer is offline
Old 12-10-2018 | 06:59 AM
F-2 Speedy's Avatar
Originally Posted by AllDodge
Should work the same as PCM (ground to turn on)
Measure voltage on pins 85 and 86. With key ON the pump should turn ON which one of the 2 will go from 12V to 0V, the other will stay at 12V. If nothing changes and they both stay at 12V, then the ECM is not applying a ground
if you're referring to the fp relay mine doesn't look like that, there is a red wire that has 12 v on it, a two wire connection that plugs into the efi harness and an orange wire that go's to the fuel pump, I'll take a pic and post it.
F-2 Speedy is offline
