New cam setup >
New cam setup
New cam setup
Old 12-16-2018 | 05:41 PM
Originally Posted by Griff
You should be fine. The risers have a tall bend, so reversion should not be a problem
I agree. Yet to remove all doubt, idle for 5 mins and remove a riser. Look down into the exhaust manifold. For better or worse your question will be answered.
Ryan00TJ is offline
Old 12-16-2018 | 09:10 PM
Originally Posted by f_inscreenname
I'm running Merc 496 Aluminum exhaust with a 288/294, Lift .585/.610, 112 L/S cam. No issues.
@.050??
That is a lot of duration for that amount of lift. Hows the valve train like those ramps? Damn
ICDEDPPL is offline
Old 12-17-2018 | 12:42 AM
This is my mark IV, 454, stroked and roller'ed to a 496. I have to say I didn't always build winners but I seemed to hit it right with this one. No reversion issues. Has a bit of a lope during idle but besides that.... Most everything is off the shelf. Open 118 heads but use +18 dome pistons making it about 9.5 to 1 so its even good with pump gas.
Build sheet >>>> http://www.supernova19.com/current_b...nova19_com.htm
f_inscreenname is offline
Old 12-17-2018 | 06:21 AM
this is my mark iv, 454, stroked and roller'ed to a 496. I have to say i didn't always build winners but i seemed to hit it right with this one. No reversion issues. Has a bit of a lope during idle but besides that.... Most everything is off the shelf. Open 118 heads but use +18 dome pistons making it about 9.5 to 1 so its even good with pump gas.
Build sheet >>>> Current Build Sheet SuperNova19.com
231/235 112
hogie roll is offline
Old 12-17-2018 | 06:33 AM
Originally Posted by SB
If one is measured at .004" and another at .006" you can't compare seat duration easily.
Edit: Also, I see f_inscreenname pic above has S pipes. These help stave off exhaust water reversion also.
Yeah I did see the S pipes after I posted and can see how they would help with reversion....good to know for future reference!
Camalot is offline
Old 12-17-2018 | 12:14 PM
Originally Posted by ICDEDPPL
@.050??
Its a hyd flat tappet cam and the numbers are similar to the Crane 420/525SC cam
Griff is offline
Old 12-17-2018 | 02:26 PM
Are you guys thinking this is to much cam?
Smoke eater is offline
Old 12-17-2018 | 02:56 PM
You'll be fine like Griff said. Very similar to the 454/420 cam. I ran that cam in a rather stock 454/365 mag single engine boat and picked up 3 mph if I remember correctly. Been years however was a worthy swap running stock heads and exhaust.
getrdunn is offline
Old 12-17-2018 | 03:38 PM
GPM
These elbows look like they would dump water in the motor every time you slow down.
GPM is offline
Old 12-17-2018 | 05:49 PM
Those aren't the ones in question though. Regardless just don't slow down. Hah.
getrdunn is offline
