500 EFI t'stats >
500 EFI t'stats
500 EFI t'stats
Old 12-16-2018 | 03:43 PM
splashandburn's Avatar
Default 500 EFI t'stats
Anyone know if there's a way to test an oil t'stat? I know you can boil a water stat to see if it opens - anything similar with an oil stat? Thanks for any help!
splashandburn is offline
Old 12-16-2018 | 05:27 PM
SB
Same. the t-stats are designed/made the same.ie: wax pellet that moves the disc open.
SB is online now
Old 12-16-2018 | 06:01 PM
Thanks. Any idea what temps they should open at?
Old 12-16-2018 | 06:14 PM
Might be stamped on the Tstat. Mine opens at 212F but is Hardin Marine. I thought the 500 EFI was supposed to open at 190F
tgorbett is offline
Old 12-16-2018 | 06:54 PM
BUP
I warmed up brand new motor oil the reason why I use motor oil because of 2 reason.
One to simulate the world it lives in and 2 is I am NOT 100 percent sure using water that corrosion or tad of it would take place however
BUP is offline
Old 12-16-2018 | 07:22 PM
Thanks BUP i was wondering about water getting into it as well. Domyou know what temp the Merc one opens at?
Old 12-18-2018 | 12:38 AM
BUP
Sorry I have been busy. anyways post # 35
Hp500 Oil Temp
BUP is offline
Old 12-18-2018 | 12:48 AM
BUP
Merc part number is 816153 and like I said - not sure how well it will do in water. It is not like a water / coolant T stat at all. For whomever has never seen one inwhich I have no idea. Would think not everyone has seen these. Just saying.
BUP is offline
