LS Build: In Progress
#143
ac delco 2008 silverado 2500 6.0. Modded. Heater hose in out tapped 3/8 and 1/2 npt. 3/8 will be plugged. 1/2 will get 12an to feed exhaust until thermostat opens. Brackets are ict billet low alternator mount truck soacing.
#148
#149
First off before you beat me up the is not the ginal mounting location and the bypass port on the stsinlesshousing will be cut off and a 90 12an stainless fitting will be tig welded in place there. It will end up on the valkey pan horizontally mounted. Just a reference on how to save a f**c ton of money vs hardin unit. That being said this moroso housing is the same as the speedmaster (pro comp). The speedmaster can be had for $20 less. This is how you make a raw water remote thermostat for in my case less than $200 per motor.
#150
Little progress on my motors.
