LS Build: In Progress >
Old 03-01-2019 | 02:45 PM
  #151
Also relocated msd box.
mggdoors is offline
Old 03-01-2019 | 03:56 PM
  #152
Originally Posted by ezstriper
Nice looking setup...not sure how the 102 mm TB going to be on a boat...may hurt the power where you need it most
where I need it the most is above 6,000. This boat is under 5000 lbs with 2 of these motors. I don’t need any extra torque. I’m sure these motors will have more horses and ft lbs than the old school 5.7’s that came out.
Hot Rod 29 is offline
Old 03-01-2019 | 04:02 PM
  #153
The old 5.7 and big blocks vs LS engines dont even belong in the same category. Light years ahead. Yours will be a goid runner just not optimal intake for rpm range of a boat but will mske good power regardless
mggdoors is offline
Old 03-01-2019 | 04:06 PM
  #154
Originally Posted by mggdoors
The throttle body will be fine. The intake will hurt you bad below 5k. Ive ran that intake on a car before. Like to rev to make good power at 6-65k plus
What engine did you have?
under 10/10 loss below 5000 rpm’s on a 6.2. But above 5000 should be 15-20 gain. It’s what I wanted. Upper end horses. Broad power curve. It will still make more power than the 5.7’s from 1500 rpm up.
Old 03-01-2019 | 04:35 PM
  #155
that intake design is no different than a 525 efi or the intake that came off of the 5.7’s. Straight runners with an open plenum.
Old 03-01-2019 | 05:15 PM
  #156
I just realuzed it is fitech. I tjought it was holley sniper intake, which is the one I tested before. Very similar design but have to testing on that intake to backup previous statement as it is not the holley. Disregard
mggdoors is offline
Old 03-02-2019 | 07:44 AM
  #157
I like the remote coil mounts.
Wildman_grafix is offline
Old 03-02-2019 | 11:50 AM
  #158
Pretty cool setup honestly. Nice tight little package. Well done OP!
Plus its an LS and we all know they rock (make big power and a monkey can work on them)!
3rdcoastpowersports is offline
Old 03-18-2019 | 06:16 PM
  #159
Update: had a back injury. Back at it.
mggdoors is offline
Old 03-18-2019 | 06:25 PM
  #160
You almost want to go straight to a museum so it doesn't get dirty. Beautiful.
BTW - Does anyone have the dyno sheet/numbers for a stock Merc 330 or 420? I'd love to see how the torque numbers compare.
242LS is offline
