LS Build: In Progress >
Old 05-02-2019 | 04:11 PM
  #261
Who needs torque anyway. Lol What’s the specs again? High compression too right? Looks like it still can’t touch a mild big block. This is good info. Been following along
Crude Intentions is offline
Old 05-02-2019 | 04:39 PM
  #262
Good numbers! Time for me to invest in an LQ4
jsboat is offline
Old 05-02-2019 | 05:28 PM
  #263
Original cam vs new cam. Both runs with single plane
mggdoors is offline
Old 05-02-2019 | 05:41 PM
  #264
SB
Originally Posted by mggdoors
Valve shrouding 101. Hit my peak dead on the head. Ended up making more power with proform 850 than pro systems 1050. And ran wayyyy better
You have data from the run(s) with the Proform ?
SB is online now
Old 05-02-2019 | 05:48 PM
  #265
mggdoors is offline
Old 05-02-2019 | 05:55 PM
  #266
looks like my 550 hp guess was very close.you did loose some weight from the bilge.
mike tkach is offline
Old 05-02-2019 | 06:14 PM
  #267
Good guess. I would say that I am pretty much at the limit of stock ls3 heads on a 4.030 bore as far as hp goes, maybe a few more if I wasnt running marine application. Valve shrouding is hurting me so the only thing left to do is porting. I am done playing around with them for the summer and am going boating. At the end of the season, mid november lol, gotta love Arizona, I will be doing cnc heads and roller rockers. Results will be posted again.
mggdoors is offline
Old 05-02-2019 | 06:21 PM
  #268
High compression? 11:1 vs stock ls3 10.8. Nope. Mild compression 91 octane gas sippers. Didnt meet my mark. Thats on me. But torque where I need it, not where it breaks drives. Hell I can rev it to 7k safely if I dare lol.
mggdoors is offline
Old 05-02-2019 | 06:30 PM
  #269
run video. Notice the lean spike from 1050 carb. Subscribe for more videos
mggdoors is offline
Old 05-02-2019 | 06:48 PM
  #270
One thing about the stock, car engines, is they have an engine management system. My 6.4L hemi is 10.9:1 stock. It also is very sensitive to octane, air temperature, fuel mixture etc. Could see some short term knock retard just from going from one gas stations 93 to another brand. It runs great, thanks to a modern engine management system that as many failsafes working nonstop to prevent detonation. Basically, they run it on the edge from the factory , and "tuning" doesnt do a whole lot for them. The engines run near peak performance thanks to all those sensors.
That beIng said, prob not where id want to be with a carburetor setup and basic ignition setup. I don't think 11:1 compression is "mild" by any means, for a pump gas boat engine. Id say its a bit closer to borderline , and a bad tank of gas away from knocking itself to death. LS or not, detonation doesnt care what you name the engine. Id keep a close on that tune . What kind of egts were you seeing from cyl to cyl?
MILD THUNDER is offline
