LS Build: In Progress >
Old 05-04-2019 | 01:24 AM
  #331
Veteran: Reserves
Originally Posted by MILD THUNDER
Sea pump? I have no data on this, but I think out of all the accessories, (steering, alternator, circulating pump), the sea pump robs the most power. I thought I remember reading here something like 15-20hp just to turn the sea pump, idk .
Hard to belive. Perhaps 2 hp or less.
P = Q x H x g x 0,4 (Kw)
p.s
Under name Volvo Penta it is a lot of LS3 marine engines. Not wery sttrong, but @ 430 hp made more prop torque like BBC HO.
plavutka is offline
Old 05-04-2019 | 02:35 AM
  #332
Originally Posted by Crude Intentions
sorry for the delay. Offshore internet is being extra ****ty. These are stock GM 502s. They have cams and box stock EQ iron heads. 8.7:1 compression which also contributes to the bsfcs being higher than normal. The plan is for blowers but still scared to pop the bravos. That dyno number is with wet exhaust and not even a set of long tubes like the 525. These cams desperately want longer runners. I’m too poor for that. Lol
for the record I’m a fan of the LS platform and think you made great power for what an LS is. I only take issue with the claim it would make a 525 look like a fool through the whole powerband and I don’t see where you beat the 525 at all. You make peak power a little higher but a fraction of the torque. This is no ball busting on the LS or what power it made just against the claims made.
You also mention there aren’t many LS powered stern drive boats yet claim they’re cheaper and better. If that were the case don’t you think there would be more than 20 of them?
Probably going to get **** for this but I can say from personal experience that the bravo will be fine. I ran bravo on both the sunny and currently on the daytona (same drives even) behind blower motors. Take off nice and dont murder the throttle below 3k. If you think your coming out of the water then get out of the gas. Ive had better luck with bravos then xr any day. And if you do have an issue much cheaper and easier to find parts for. Keep the oil changed( I do it every 10 hours with the engine oil). Might sound excessive but oil is cheaper than mechanical. Last but not least drive shower, preferably wag engineering billet cap. If it breaks it will most likeley be the floor. Easy fix. I have two spare bravos sitting still waiting for failure. Keep in mind mine are behind a cat with 5 blades. Very hard on drives but still ticking. Btw my drives on my daytona are 1994.
Are you running the eq 320? Thats what I ran on the blower motors. Good heads but heaaaavvvvyyy
mggdoors is offline
Old 05-04-2019 | 02:37 AM
  #333
p.s
I havent found but a 4 hp variable on any run. Some of it has to be the pump but not every run is identical either
mggdoors is offline
Old 05-04-2019 | 08:50 AM
  #334
SB
I dont think anyones against him. But if we're talkin shop, lets talk shop. He's made about two dozen claims in this thread, that are simply untrue. Things like his engines are going to run circles around a 525 merc, use way less fuel, his single pattern cam will make more torque than a dual pattern, and so on
I will read from the beginning then. Thus why I asked. Thanks,
SB is online now
Old 05-04-2019 | 10:16 AM
  #335
Yes EQ 320s. Trust me I want nothing to do with XRs. So far my combo has lived for 70hours. I do engines and drives every 25 hrs.
Crude Intentions is offline
Old 05-04-2019 | 10:48 AM
  #336
Im surprised the twin LS package would be 1,000 lbs less than a 525efi engine. The ls engine is 500lbs lighter than the 525efi?
i weighed my mpi gen+ 350’s vs my new LS3’s and I’m saving nearly 400 lb each. That’s SBC vs LS.
Hot Rod 29 is offline
Old 05-04-2019 | 11:09 AM
  #337
LS3 is aluminum block right? We are comparing iron blocks here
Old 05-04-2019 | 08:54 PM
  #338
Default DynoTorque Compares
Here's a torque comparison of the 4 dyno sheets in this thread.....
242LS is offline
Old 05-04-2019 | 09:20 PM
  #339
Here is a 454..basic 525 sc clone, 8.5:1, AK alum heads, 731 cam... Without doing a lot of number crunching, it was a pretty budget friendly build
phragle is offline
Old 05-04-2019 | 09:26 PM
  #340
bck's Avatar
bck
Charter Member#568
What magic is this? I'd like to do this.
Straight bottoms and flat decks
bck is offline
