Help needed, Drive suggestions >
Old 02-13-2019 | 08:36 AM
1000 hours. it has proven itself to work i that app. pull it off and have it gone thru by somebody that will stand behind their work. your maintanance and driving work obviously. i would just keep it the same.
beaver 3 is offline
Old 02-13-2019 | 08:38 AM
F-2 Speedy's Avatar
AADS addresses several issues with their 1-4 upgrades but the upper gear set, until someone develops a better, stronger upper gear set they will fail. you can treat XR gears all you want but they'll break.
F-2 Speedy is offline
Old 02-13-2019 | 12:24 PM
Thank you for the responses! I am assuming that some of you have used AADS before and have been happy. What are your opinions on the upgaded gear sets?
WHITEOWL is offline
Old 02-14-2019 | 01:41 AM
Originally Posted by WHITEOWL
The boat has just over 1600 hours on it now. The previous owner replaced the drive at 600 hours and sold the boat. My world is a lot different as far as excelleration and running. I am honestly pleased with what I have but figured that I would never get this lucky again, so was hoping when I do have an issue to go with something better. Is there a better gear set to go with? And also who does the best at rebuilding these drives?
Merc is the only choice for gear sets. Some places will cryo treat the Merc gears.
Griff is offline
Old 02-26-2019 | 02:12 PM
The boat has a jackshaft to the drive. The B3x drive that is on the boat now has somewhere around 1000 hrs on it with not major issues. I do have a drive shower and my cruise is around 3400 RPM. A direct replacement would be great, so I could hopefully just bolt up and go when something does happen. I can always just go back with the Bravo but I like overkill and not having to worry about things. Thank you for the input and any more is greatly appreciated as im trying to get educated.
Hi Whiteowl,
We're also in NC. What kind of Drive-Shower do you have on your outdrive?
SimrekinNC is offline
Old 02-26-2019 | 03:13 PM
I have a simrek shower on my B3X and am very happy with it.
WHITEOWL is offline
Old 02-26-2019 | 06:00 PM
SABER28's Avatar
Originally Posted by Griff
The odds of anybody on OSO having 1000 hrs on an outdrive are slim to slimmer. Just stick with what you've got.
i have over 1000 on the original drives in my 28 Saber. only had 330's in front of them. now with the 650's i'm sure there time is coming.
SABER28 is offline
