cutting jacketed exhausts >
Old 03-12-2019 | 08:43 AM
Default cutting jacketed exhausts
Anybody ever tried to cut or otherwise shorten jacketed exhausts?
I was thinking about buying these and cutting them down to where I needed:
https://www.ebay.com/itm/1-PAIR-EXHA...torefresh=true
I assume that there is an inner pipe and an outer pipe and that they are fastened together at the end. If so, I should be able to cut them off and tig them back together at the new cut end.
Am I thinking about this right?
Thanks,
Russ
highplainsdrifter is offline
Old 03-12-2019 | 12:26 PM
TomZ's Avatar
I think the real issue is the access to the areas that need welding. When they're built, the inside jacketing is welded up in stages with the outside following in step. It would be probably be better to fabricate a new end to prevent leaks. I'm not the most knowledgeable with TIG, though I can definitely see having a hard time getting a torch into the pipe, but that's me.
TZ
TomZ is offline
Old 03-12-2019 | 12:46 PM
14 apache's Avatar
If you just need to just shorten the down leg won't be bad. If you have good skill it can be done.
14 apache is offline
Old 03-12-2019 | 12:54 PM
You should be able to cut them and then just weld maybe about 4 or 5 1/2 inch welds to connect the inner and outer pipes.
You will need to switch to 4.5" exhaust hose and exhaust tips though since you wouldn't be necking the end down.
This is the way my dry through the transom CMI's tails were made from CMI originally.
Griff is offline
