What bbc rods?
I may be wrong but those look like regular ole gm dimple rods to me...from the eagle ones I found in a google search they all had bolts like 12 point arp bolts bolting the cap on....those look like the standard gm nuts to me...like I said could be wrong
i think so too. pistons are je700 series with very slight dome, could be stock bbc 502 rods and pistons.
The stock GM rods would not have the "6135" cast into the beam or the numbers etched into the parting line. Those are most likely either Eagle or Scat. I cant remember if the Eagle's have "ES" along with the "6135" on the beam.
You might want to also give Eagle a call. They are pretty good about answering questions. They might be able to tell you something based on the rod bolts and the etched numbers at the parting lines.
