Anyone ever try the BBC trick flow intake manifold? 540-565 ci >
Old 04-24-2019 | 11:52 AM
SB
Originally Posted by Baja Rooster
With all of these spacers it seems like we're just getting back to the venerable tunnel ram.
You can add 4" of spacers or more and it's still not a Tunnel Ram.
Just like adding spacers to a dual plane is not making a single plane.
Making something share 1 characteristic does make something become another.
SB is online now
Old 04-24-2019 | 01:39 PM
https://rehermorrison.com/product/an...ersion-plates/
These made an extra 8-12 horsepower on my 540s.
payuppsucker is offline
Old 04-24-2019 | 02:37 PM
articfriends's Avatar
Most these bigger motors if you add a tunnel ram to dyno sim it shows signifigant gains with virtually no torque loss. I have never built a motor with a tunnel ram or dynoed one with one but i plan to!
articfriends is offline
Old 04-24-2019 | 04:36 PM
SB
Dart Tunnel Ram. Trust me. Famous last words !ha,ha,ha.
SB is online now
Old 04-25-2019 | 08:29 AM
14 apache's Avatar
Almost did the dart tunnel rams but ended up going kinsler injection off class one race motors with new ecu's don't think it cost that much more with used intakes.
14 apache is offline
Old 04-25-2019 | 09:10 AM
How well would a tunnel ram work with a boat motor? I always assumed from my old car days the low end would suffer to much in a single speed boat.
Wildman_grafix is offline
Old 04-25-2019 | 09:13 AM
Richie Zul did quite a few of them so I'm thinking they work pretty well.
Old 04-25-2019 | 09:39 AM
That depends on runner Csa and length. Sized properly they will always be better due to the straighter line to the valve.
hogie roll is offline
Old 04-25-2019 | 09:41 AM
SB
And all Dart's
Back then, we didn't have 500cid-700cid engines running around everywhere. Also,todays cyl heads and hyd roller cams are lightyears ahead. Bolt on 400cfm raised runner heads to your door as quick as you type in your cc #. Amazing world we are in.
Lastly, a certain tunnel ram isn't the same as the net. Runner cross sectional area and length and plenum volume all determine what rpm vs cid vs power it ill make. Same with single pane intakes...thus why it drive's me nuts (single plane intake manifolds mostly) when talked about generically.
Another thing is, people back then didn't really realize the different timing requirements of the tunnel rams. They typically love a ton of initial timing.
SB is online now
Old 04-25-2019 | 10:52 AM
Thats sort of my point. Growing up I only saw tunnel rams on jet/V drive boats and never on a street car because they were too “radical”. Technology has improved so much that now we’re adding spacers upon spacers to single planes creating a bastardized version of a tunnel ram without the benefit of better fuel distribution.
I think given the advancements of engine building the tunnel ram may be a good option again.
Baja Rooster is offline
