Max overlap with these risers >
Old 04-17-2019 | 12:48 PM
Default Max overlap with these risers
JaniH is offline
Old 04-17-2019 | 05:24 PM
What is your build. If your searching cams I wouldn't get anothing under 112-114 lsa. I would think try and keep overlap btwn 8-14. Those risers will revert relatively easily. Especially if you idle a lot. I've been pretty fortunate over the years with the exception of my first marine build with a 109 lsa and stock cast manifolds. I never idled much with the exception of docking. Over 1,500 rpm out the channel however my first experience with reversion. It would still suck in some water periodically and get milky oil.
Does the water dump just past the 90 at the weld or closer to the end of the tip.
getrdunn is offline
Old 11-10-2019 | 06:56 AM
It dumps the water to the tip, going to extend the inner pipe almost to the transom. My build is 502 with ported peanut heads. Currently looking for flat tappet cams with tight 108lobe and 224 @.050. Duration, overlap 9° @.050 and 59° advertised. Lifters are rhoads original wich will cut the overlap to 48° advertised @ idle
JaniH is offline
Old 11-10-2019 | 03:42 PM
How fast do you want to spin it?
hogie roll is offline
Old 11-11-2019 | 01:30 AM
I think 5000rpm and it is all done, hopefully more. Have not measured intake runner volume after porting.
JaniH is offline
Old 11-12-2019 | 05:09 PM
Here is valve timing comparison of my lunati streetmaster 275/275 hyd flat vs Crane 731 hyd roller. I thought crane 731 would be good cam to compare, because it is almost always suggested here for mild bbc builds. If i have understood right the 731 should work without reversion even with silent choice. what you guys think?
Lunati. 275/275. 225/225. 104,ICL. 108 lobe.
Advertised. IVO=33.5 btdc. IVC=61.5 abdc. EVO=69.5 bbdc. EVC=25.5 atdc.
.050. IVO=8.5 btdc. IVC=36.5 abdc. EVO=44.5 bbdc. EVC=0.5 atdc.
Overlap. Advertised= 59. .050= 9.
Above Lunati cam with rhoads lifters. 15 degree reduced duration @idle.
Advertised. IVO=26 btdc. IVC=54 abdc. EVO=62 bbdc. EVC=18 atdc.
Overlap. Advertised= 44.
Crane 731. 286/296. 226/236. 107,ICL. 112 lobe.
Advertised. IVO=37 btdc. IVC=71 abdc. EVO=86 bbdc. EVC=32 atdc.
.050. IVO=6 btdc. IVC=40 abdc. EVO=55 bbdc. EVC=1 atdc.
Overlap. Advertised= 69. .050= 7.
JaniH is offline
Old 11-12-2019 | 05:37 PM
GPM
GPM is offline
