Bravo One Replacement Advice >
Old 04-28-2019 | 03:10 AM
Default Bravo One Replacement Advice
Hello, I am looking to replace my Bravo One transom assembly and outdrive on my 2005 Baja H2X completely.
My concern or question is are there minor differences between older Bravo Ones and new Bravo ones or are they a direct and exact replacement, especially with regard to all the connections to the drive.
I want to make sure the drive I buy is the correct one from the start. I will need a 1.5 ratio.
Please let me know of anything I should be aware of.
Thanks in advance!
Jutter85 is offline
Old 04-28-2019 | 06:46 AM
What engine is in the boat ?
JaayTeee is offline
Old 04-28-2019 | 06:48 AM
Look for any after 1995 and your good.
AllDodge is offline
Old 04-28-2019 | 07:19 AM
496 Mag
Jutter85 is offline
Old 04-28-2019 | 07:20 AM
Great, Thanks!
Jutter85 is offline
Old 04-28-2019 | 11:07 AM
https://www.mercruiserparts.com/6315...rtcraft-transo. This is the t/a listed, depends on if the trim sender is 2 or 3 wire, a 05 496 would have most likely had a slope backed Bravo 1, anything will bolt up though, the really, really old drives won’t have a oil reservoir valve in them
JaayTeee is offline
