Slow starter - BBC >
Slow starter - BBC
Slow starter - BBC
Old 05-02-2019 | 06:02 AM
is the starter painted,especially the mounting pad?and the block?may be a bad ground.you using starter mounting bolts w/ the knurls on them?
sutphen 30 is offline
Old 05-02-2019 | 06:13 AM
I do have the correct starter bolts, but will verify good contact.... great suggestion!
sandslot is offline
Old 05-02-2019 | 08:52 AM
TomZ's Avatar
Make sure it’s shimmed properly, too.
TomZ is offline
Old 05-05-2019 | 07:53 AM
Originally Posted by Ballistic Beak
I'm having the same issue, looking forward to the replies.
Ryan
Ryan, I installed the shortest and thickest cable I could find (size 1ot) and it’s full of spunk now. I had the ends wedged/crimped on at the local battery store
good luck
sandslot is offline
Old 05-05-2019 | 09:37 PM
SABER28's Avatar
dont buy MSD starters , this is the result. yes they were shimmed correctly.
SABER28 is offline
Old 05-05-2019 | 09:40 PM
SABER28's Avatar
whoops..
nice!
total junk
wasted
SABER28 is offline
Old 05-05-2019 | 10:04 PM
14 apache's Avatar
That ring gear looks funny with the teeth like it was to hard. What's the motor combo?
14 apache is offline
Old 05-05-2019 | 10:07 PM
14 apache's Avatar
Have not seen a starter knock teeth off like that for no reason. Something other than the starter did that.
Old 05-06-2019 | 07:01 AM
SABER28's Avatar
557 cid, 650 hp, 9.3 compression. starter bendix's half the time wouldnt come out all the way, buzzing the ring gear. put the exact ring gear back on and used some new tilton super starters and havent had a problem since. MSD told me they had problems with them, then when they found out i wanted labor time to pull 2 boat engines they lied and said they never had problems with them. then after six months of avoiding me the best they could they agreed to pay 2K for the repairs. which they reneged on 24 hours later. keep in mind this ruined my once a year boating vacation and knocked out over half my summers boating. took ten years to save and build these engines. MSD products are crap. btw at least summit stepped up and refunded the starters that MSD still had in their possession. screw their ignitions too, been using daytona cd-1 boxes, they are great.
SABER28 is offline
Old 05-06-2019 | 07:29 AM
good luck
Thanks! - Did you do the (+) from the battery to starter? Or other cables also?
Ballistic Beak is offline
