Oil thermostat systems >
Old 05-10-2019 | 10:02 AM
If you have room to change the oil filter you can use a thermostatic adapter. I used this Earls 504. Oil tstat begins to open at 160* and is fully open at 180*. -10 ports.
Ryan00TJ is offline
Old 05-10-2019 | 05:46 PM
These guys make good thermostats that flow up to 20 gpm, and you can get them with -12 AN fittings. They have sandwich type adapters too but no flow rating on them.
tomcat is offline
Old 05-10-2019 | 06:03 PM
GPM
Tried it, sitting on the shelf, could have been my application.
GPM is offline
Old 05-11-2019 | 02:11 AM
Rhythm and Blues's Avatar
I’m runnin some Mr.Cool tstat controlled coolers on my 580/780s in my Cafe. In cold ocean h20 I’m between 190-200 oil temps, no milkshakes... I have a dirivetive of these, custom length..mrc-cph-775.html
Rhythm and Blues is offline
Old 05-11-2019 | 06:36 AM
I run the same Hardin block adapter that texascuda showed. It works flawlessly. Before I added it, I could wait 20-30 min. To show any oil temp. My temp sender is in the pan of my na 540.
ph1971 is offline
Old 05-12-2019 | 05:02 AM
Full Force's Avatar
What temps you see in pan?
Full Force is offline
Old 05-12-2019 | 11:03 AM
Not sure if you were asking me, but my temps have been between 180 and 210 up to 4500 rpm. The temp creeps to 240 if I run hard@ 5400 for any more than a minute or two. I just upgraded my cooler this week to see if that last number can be kept under 230. I am also closed cooled at 150 water temp.
ph1971 is offline
Old 05-12-2019 | 11:23 AM
Full Force's Avatar
240 in the pan is not a bad reading at all though ... that’s reading the hot side that’s actually a great temperature
