Need Help To Id Block >
Old 11-01-2002 | 01:15 PM
JUSTONCE's Avatar
Default Need Help To Id Block
Its a 454 I found and want to know if its worth getting into i jotted down these numbers 14015445 gm 3p c219 of the rear of the block and there was a # on the front on top of the timing small# hard to see think its 104069 X1 . The intake manifold # is 6269318 if that helps anything. Want to know if its a 420horse mag. of 330horse.??? any input is greatly appreciated.
JUSTONCE is offline
Old 11-01-2002 | 02:22 PM
Official OSO boat whore
If the intake is a low rise cast iron piece then the engine is definately a 330 454 (sometimes they called the 330 a mag motor). If it has a high rise aluminum intake and rectangular ports, then it's a 454mag (or better). If it's an original merc motor, there will be a tag rivited to the bellhousing down by the starter. The serial number will tell what it originally was.
Cord is offline
Old 11-01-2002 | 02:27 PM
Luv-N-It's Avatar
JUST ONCE YOU HAVE A PM
Luv-N-It is offline
Old 11-01-2002 | 02:31 PM
Luv-N-It's Avatar
TRY PUTTING THOSE #'S IN ON MERCS WEBSITE AND SEE WHAT YOU COME UP WITH OR TRY BAM'S WEBSITE
Luv-N-It is offline
Old 11-01-2002 | 05:11 PM
cigarette1's Avatar
Member #2 ....Jeeezz
When you say bellhousing, is that part of the block or is it a separate piece? I'm not being a smart ass, the police want to destroy my motors because a Merc SR# tag was removed from an area near the starter.
G
cigarette1 is offline
Old 11-01-2002 | 07:21 PM
Kanookstr's Avatar
32' SUNSATION
Just once, the year of that block is between 78-90 it can be either 2 or 4 bolt main. This a fantastic web site I use for all casting numbers.
Casting Numbers
Kanookstr is offline
Old 11-02-2002 | 09:04 PM
JUSTONCE's Avatar
thanks for the input, no idea's on horsepower that block was? I'm not sure if the intake is orig. the moter haas roller rockers on it so im wondering if there is ay other perf. upgrades to it or if its a stock h.o. motor???
JUSTONCE is offline
Rockfish71
4
05-29-2008 01:39 PM
smokin' gun
Wanted
1
04-15-2008 11:27 PM
handfulz28
10-15-2006 02:25 PM
chrisf
01-13-2006 04:44 PM
Dregsz
0
06-25-2005 12:26 AM
