Oil out the exhaust >
Oil out the exhaust
Oil out the exhaust
Old 06-04-2019 | 07:00 AM
Default Oil out the exhaust
Ok, 496 BBC, I have oil blowing by and out the exhaust. On a hard run, about 2hrs I run through 4q of oil. It's not burning it, its raw dump out the exhaust. I have zero power loss, and the compression on each cylinder is above 150. Any ideas?
zeek987 is offline
Old 06-04-2019 | 07:20 AM
Oil cooler
underpsi68 is offline
Old 06-04-2019 | 07:25 AM
I should mention that I do have signs of build up on my plugs.
zeek987 is offline
Old 06-04-2019 | 08:54 AM
Wrong dipstick?....causing you to overfill the pan....oil coming out breather into the intake....being blown out?
Since:
1. "no power loss"
2. oil build up on plugs
3. Good compression
It be looking for a leak down tester too.....
Is this a fresh build? how many hours? Details.
I like the oil cooler idea...but then you shouldnt have build up on the plugs.
SS496 is offline
Oil cooler
Crude Intentions is offline
Old 06-04-2019 | 08:58 AM
Knot 4 Me's Avatar
Are you running guide seals on exhaust valves? Excessive guide clearance?
Knot 4 Me is offline
Old 06-04-2019 | 09:04 AM
pressure test the oil cooler.
mike tkach is offline
Old 06-04-2019 | 09:10 AM
BUP
Pressure test the oil cooler first very easy to do --- if that checks out good on the pressure testing - next place I would check would be --- possible intake manifold gasket - a engine serial number is a must.
Later 496 changed to a bigger intake manifold gasket for better sealing because the first gen was not holding up over time. As you mentioned plugs have build up but is that OIL OR GAS.
BUP is offline
Old 06-04-2019 | 09:14 AM
4qts in 2 hours is a lot for blow by. I would be pulling and testing oil cooler ASAP. I mean that’s half the pan oil coming out. Mine did something similar and it was cooler.
Old 06-04-2019 | 10:23 AM
The motor is a built carb, 496, not a mercruiser, I run a larger oil pan so the boat actually takes about 10+ quarts. I have a guy that is going to do a leak down test for me but I have to wait 2-3 weeks. The oil cooler is a good idea, I never thought of that. It is not a stock one either of course, it is a much larger one. But that does not mean something didnt happen to it.
zeek987 is offline
