Bbc help
Old 06-15-2019 | 08:46 AM
Tried plugs also it’s popping out of the intake.
Bill0072 is offline
Old 06-15-2019 | 09:20 AM
14 apache's Avatar
It could be tach like SB said. Have you had it at wot at like 3500rpm ?
14 apache is offline
Old 06-15-2019 | 09:23 AM
The boat runs perfect right up to 3800 when I go wot to 4000 or a little above that’s when it starts to spit and sputter through the intake
Bill0072 is offline
Old 06-15-2019 | 10:18 AM
Check valve lash. Might be a vacuum leak.
joev01 is offline
Old 06-15-2019 | 10:30 AM
14 apache's Avatar
You can put a vacuum gage on it and see if it has a bounce below 3500 and if you can't find anything else disconnect alternator I doubt it will do anything but have seen it with a crank trigger before. Also check for 12v
Old 06-15-2019 | 10:37 AM
Also check for a broken valve spring.
fbc25el is offline
Old 06-15-2019 | 06:03 PM
Alternator might have something to do with it that was not on it at the dyno. What do you mean crank trigger??
Bill0072 is offline
Old 06-15-2019 | 06:56 PM
14 apache's Avatar
I had a problem with a crank trigger next to an alternator once the magnetic field was upsetting the pick up. Last thing to try unplugging alternator
Old 06-15-2019 | 06:57 PM
Ok sorry I wasn’t familiar with a crank trigger. My engine does nit have one
Bill0072 is offline
Old 06-15-2019 | 09:51 PM
Tinkerer's Avatar
Sounds to me like it is running out of fuel.
Is it possible that the fuel lines and or tank pickups are too small or blocked. New engine needs more fuel.
The popping sound is it kind of a pop through the carb. " lean Pop"
Tinkerer is offline
