(Another) Hardin pump issues thread... >
Old 06-19-2019 | 07:33 AM
Originally Posted by sutphen 30
is it me or is there a crack on the lower left port in the first pic?
Thats a bump in the machining. It’s quite pronounced to the touch.
Baja Rooster is offline
Old 06-19-2019 | 08:06 AM
You can also see a bump in there about half way in where the port starts. Putting a straight edge on it it rocks back and forth about a 1/64”. Id think the rubber impeller could manage that difference.
Im thinking of running something like a caliper home in there as the grooves really catch the fingernail. Any thoughts against that?
Old 06-19-2019 | 10:02 AM
rv
What did Hardin have to say about your issue?
rv is offline
Old 06-19-2019 | 10:23 AM
I sent an email with the same info here. Just waiting to hear back.
Its an otherwise beautiful piece and using the threading fittings allows me to eliminate any molded hoses and couplers/hose clamps. Going back to plastic would be a pain with my current hose routing.
Old 06-19-2019 | 11:26 AM
Old 06-19-2019 | 11:58 AM
Have you tried taking it to the ramp and bringing up the RPM to around 2,000?
We did impellers on my buddy's 575SCI's and couldn't get them to build any pressure on the hose. Put it in the water and brought the RPM up to 2,000 and it built pressure almost instantly.
c0ncEpT is offline
Old 06-19-2019 | 01:22 PM
Yep. Blipped the throttle a few times and Idled about a hundred yards through the no wake zone and as soon as I hit the gas everything started screaming in protest.
Old 06-19-2019 | 01:26 PM
Hardin was saying that it’s the “squish” on the ends that creates suction. The blades were completely smoked but the ends of the impeller look virgin. The wear plate had nothing but a little assembly grease on it.
Old 06-19-2019 | 01:36 PM
14 apache's Avatar
Do you have a caliper to measure the depth of the stainless housing?? Might be to long.
14 apache is offline
Old 06-19-2019 | 02:26 PM
Are the swirl patterns on both end plates uniform? After I rebuild mine, I turn the pulley by hand before reinstalling it. Does yours have that freedom of movement? It should be tight but turn by hand. Silicone spray works really well instead of grease.
ph1971 is offline
