(Another) Hardin pump issues thread... >
Old 06-19-2019 | 06:14 PM
Originally Posted by 14 apache
Do you have a caliper to measure the depth of the stainless housing?? Might be to long.
The depth reads on average 2.08 and if I give the impeller a firm reading it’s pretty much 2.00.
Baja Rooster is offline
Old 06-19-2019 | 06:22 PM
It looks like nearly an 1/8” gap. This is the oem Merc impeller. I got a Sierra one laying around and brand new measures even smaller.
Old 06-19-2019 | 06:27 PM
You have this wear plate in the back of the pump correct?
IGetWet is offline
Old 06-19-2019 | 06:42 PM
Nope. That may explain a lot.
Old 06-19-2019 | 07:59 PM
14 apache's Avatar
Good job on the find.
14 apache is offline
Old 06-19-2019 | 08:36 PM
The Hardin email mentioned it, “inner wear plate”. I do have the same pump and thought as I was putting it together how the pump probably wouldn’t work at all if that small piece was missed.
IGetWet is offline
Old 06-19-2019 | 08:47 PM
I wonder if Brembo has the same problem?
ph1971 is offline
Old 06-19-2019 | 09:07 PM
True. In the haste of wrapping up a full rebuild trying to get it wet for the weekend it was missed. I vaguely remember it looking like a scrap blank of some sheet metal punch. OSO braintrust FTW!
Old 06-19-2019 | 09:17 PM
I asked him. He said it’s in there. He gets pressure, just not enough, like 15is instead of 30+psi.
IGetWet is offline
Old 06-19-2019 | 10:22 PM
On to another thing...whatcha all think about the machining on the inside? Seems like it would wear on the rubber a bit.
