-   -   (Another) Hardin pump issues thread... (https://www.offshoreonly.com/forums/general-q/361333-another-hardin-pump-issues-thread.html)
Baja Rooster 06-18-2019 07:09 PM
I’ve had a ***** of a time getting this to prime. I’ve tried assembling with dish soap then marine grease instead, and new Merc impellers each time with the same result. The water is fed via a tee and garden hose right in front of the pump. I closed the valve before the sea strainer to force feed water into the engine but it still won’t pull if the valve is open and it just dumps out the drive.
When i run my finger across the machined surface and it feels like like it was polished with 80grit and it crowns in the middle. Everything is brand new.
https://cimg9.ibsrv.net/gimg/www.off...d9d6c79c6.jpeg
14 apache 06-18-2019 07:30 PM
No chance lines are on wrong? How are the dimensions to stock housing depth of bore and pinch area?
Baja Rooster 06-18-2019 08:05 PM
ive gotten it wrong before so I triple checked. Looking at the front of the engine things turn clockwise and the intake hose is on the top with the bottom out to the oil cooler/engine.
14 apache 06-18-2019 08:23 PM
The right port in the picture is out.to motor?
Baja Rooster 06-18-2019 08:44 PM
I’ll check again when I get home.
SABER28 06-18-2019 09:01 PM
this actually can get confusing. sounds like you have the lines on backwards?
F-2 Speedy 06-18-2019 09:06 PM
on the mercury pumps the rotation is from the back not front
Baja Rooster 06-18-2019 11:03 PM
Yes, from the back it is left hand rotation. They even give you handy instructions engraved on the back of the housing. The 90° fitting on the bottom is the output going to the engine.
https://cimg6.ibsrv.net/gimg/www.off...6e4b935d1.jpeg
Brembofreak 06-19-2019 01:32 AM
I have take my out and work after holiday more with the Hardin housing! Use now Merc Housing to be safe in holiday.Michael
sutphen 30 06-19-2019 05:29 AM
is it me or is there a crack on the lower left port in the first pic?
Baja Rooster 06-19-2019 07:33 AM
Thats a bump in the machining. It’s quite pronounced to the touch.
Baja Rooster 06-19-2019 08:06 AM
You can also see a bump in there about half way in where the port starts. Putting a straight edge on it it rocks back and forth about a 1/64”. Id think the rubber impeller could manage that difference.
Im thinking of running something like a caliper home in there as the grooves really catch the fingernail. Any thoughts against that?
https://cimg8.ibsrv.net/gimg/www.off...0a46ced9f.jpeg
rv 06-19-2019 10:02 AM
What did Hardin have to say about your issue?
Baja Rooster 06-19-2019 10:23 AM
I sent an email with the same info here. Just waiting to hear back.
Its an otherwise beautiful piece and using the threading fittings allows me to eliminate any molded hoses and couplers/hose clamps. Going back to plastic would be a pain with my current hose routing.
Baja Rooster 06-19-2019 11:26 AM
https://cimg8.ibsrv.net/gimg/www.off...09eff4672.jpeg
c0ncEpT 06-19-2019 11:58 AM
Have you tried taking it to the ramp and bringing up the RPM to around 2,000?
We did impellers on my buddy's 575SCI's and couldn't get them to build any pressure on the hose. Put it in the water and brought the RPM up to 2,000 and it built pressure almost instantly.
Baja Rooster 06-19-2019 01:22 PM
Yep. Blipped the throttle a few times and Idled about a hundred yards through the no wake zone and as soon as I hit the gas everything started screaming in protest.
Baja Rooster 06-19-2019 01:26 PM
Hardin was saying that it’s the “squish” on the ends that creates suction. The blades were completely smoked but the ends of the impeller look virgin. The wear plate had nothing but a little assembly grease on it.
https://cimg4.ibsrv.net/gimg/www.off...74421af0b.jpeg
https://cimg5.ibsrv.net/gimg/www.off...18be7ea65.jpeg
14 apache 06-19-2019 01:36 PM
Do you have a caliper to measure the depth of the stainless housing?? Might be to long.
ph1971 06-19-2019 02:26 PM
Are the swirl patterns on both end plates uniform? After I rebuild mine, I turn the pulley by hand before reinstalling it. Does yours have that freedom of movement? It should be tight but turn by hand. Silicone spray works really well instead of grease.
Baja Rooster 06-19-2019 06:14 PM
The depth reads on average 2.08 and if I give the impeller a firm reading it’s pretty much 2.00.
https://cimg0.ibsrv.net/gimg/www.off...a4f7ec58e.jpeg
https://cimg1.ibsrv.net/gimg/www.off...121135d35.jpeg
Baja Rooster 06-19-2019 06:22 PM
https://cimg7.ibsrv.net/gimg/www.off...18847f22d.jpeg
It looks like nearly an 1/8” gap. This is the oem Merc impeller. I got a Sierra one laying around and brand new measures even smaller.
IGetWet 06-19-2019 06:27 PM
You have this wear plate in the back of the pump correct?
https://cimg3.ibsrv.net/gimg/www.off...f51ea4ed6.jpeg
Baja Rooster 06-19-2019 06:42 PM
Nope. That may explain a lot. :p
14 apache 06-19-2019 07:59 PM
Good job on the find.
IGetWet 06-19-2019 08:36 PM
The Hardin email mentioned it, “inner wear plate”. I do have the same pump and thought as I was putting it together how the pump probably wouldn’t work at all if that small piece was missed.
ph1971 06-19-2019 08:47 PM
I wonder if Brembo has the same problem?
Baja Rooster 06-19-2019 09:07 PM
True. In the haste of wrapping up a full rebuild trying to get it wet for the weekend it was missed. I vaguely remember it looking like a scrap blank of some sheet metal punch. OSO braintrust FTW!
IGetWet 06-19-2019 09:17 PM
I asked him. He said it’s in there. He gets pressure, just not enough, like 15is instead of 30+psi.
Baja Rooster 06-19-2019 10:22 PM
On to another thing...whatcha all think about the machining on the inside? Seems like it would wear on the rubber a bit.
Knot 4 Me 06-20-2019 07:32 AM
Mine looked the same and did not wear the impeller. Changed the impeller out this spring after 2 seasons and the impeller still looked new. Never had any pressure issues running this pump. In fact, my pressure picked up over stock at idle. And yes, that inner wear plate would be easy to miss. And on my pump was a bear to get the old one out to replace with the rebuild kit.
Baja Rooster 06-20-2019 11:52 AM
Fair enough then! And thanks for everybody’s help on sorting out my boneheaded oversight.
Ive ordered the plate and will post the results. I may still run a small hone in that baby just because. ;p
jwurl 06-20-2019 05:10 PM
I have the same pump. I change my impeller once a year as maintenance . Never have had a problem with any part of it. Jeff Wurl
14 apache 06-20-2019 05:13 PM
your going to need very thick grease. I hope harden gives you something for the pain
Rookie 06-20-2019 08:11 PM
They did give him something for the pain... the wear plate that he forgot to install. lol
Glad it was an easy fix.
14 apache 06-20-2019 08:32 PM
I didn't see the part where he left it out lol.
Knot 4 Me 06-21-2019 07:08 AM
Thin coat of white lithium is all I have ever used to pre-lube any impeller in any housing. I believe the Hardin rebuild kit also suggests using lithium grease.
F-2 Speedy 06-21-2019 07:35 AM
you threw it away
thirdchildhood 06-21-2019 08:11 AM
I've been running this pump on my 525 for years with no problem. Used to change impeller every year but it always looks like new so now I do it every 2 years.
BUP 06-21-2019 08:56 AM
water base KY or glycerin to install impellers, Johnson pumps has done many studies on this and have found glycerin to be the best for installing impellers. Glycerin -- It washes out at start up very very quickly - many other products do not wash out very quickly. And dish soap exacts the oil out of impellers. All rubber products are a form of an oil base .
Johnson includes the glycerin in every impeller kit they sell for a reason. Like I said they tested everything
Actually tech speaking clean water is the best for impellers no matter how you slice it because thats what they live in 24 / 7
Impellers and the housing is all about tolerances - when wrong it does not work nor flow correctly
