MSD distributor failure
I'd try and see what happened to the MSD units just for curiosity. The ones i had were plagued with rust issues internally. And when the motors started to run bad i knew one of the advance springs had broken messing up the timing....after i sent them to MSD for a "refurbish" i sprayed them down with CRC to keep the rust off and they worked ok from then on out...but it was a yearly thing to spray them down at the star of the season to make sure i didnt have problems....
-Wally
-Wally
Never been a fan of the all in one units of any brand, never saw one that worked. I'm running a basic MSD distributor that's locked and using a Daytona Sensors box to manage timing. The Daytona Sensors will do idle control by using timing and it allows me to retard timing with a switched input when I need to run marina gas which is usually 90 octane vs 93. Still getting it programmed will have to report back when I get it set up.
Rust in MSD! I had a one motor last Saturday that was back popping, I was scratching my head wondering what it could be. So I pulled the Cap off the distributor and it looked fine. Then I looked at the Reluctor and it and the Magnetic Pickup, both had tons of rust on them!! I cleaned the reluctor up with emery cloth and the back popping / miss went away. Yesterday I reached out to MSD and asked of they have one that wont rust. They said the one treated with Zinc is for a Marine environment. So I ordered two and two more Pickup's. The Tech-line guy said Rust shouldn't affect anything unless the rust is coming off... By the picture, mine had a lot of rust!
Loading up at idle
Am I correct that with the msd ignition box you can fix the mechanical advance in the distributor & so the box takes care of the advance? No springs to worry about rusting?
I’m furious I spent $450 each on two marine distributors & two coils only to have problems right off the bat! This stuff should be bullet proof!
im going to be double pissed if I buy msd boxes at $350 each x 2 & find out they fail every couple of years!
MSD makes a box that you can program the ign curve but it's not cheap (or for marine). BTW, MSD boxes seem to live longer if not mounted to eng. Mine are mounted to glass using orig shock mounts and they're at least 7 years old now.
https://www.holley.com/products/igni...rip/parts/6530
You mentioned new builds. Lots of opportunities for variation in intake height. If it's a bit higher than expected, the teeth on the dist gear won't properly engage the teeth on the cam gear. If it just barely engages, it could run for a little while then die when gear teeth wear a bit. That's why I asked you prev if you confirmed dist was turning or not. You can usually tell if engagement is good by how much the rotor turns as the dist is seated the last 1" or so. It should turn abt 1/8 of a revolution as it meshes with the cam gear.
The types of metals for the dist gear and cam gear need to be compatible too. If not, the dist gear will wear very quickly. If turning a high-perf oil pump, it only exacerbates the problem.
