MSD distributor failure >
Old 06-22-2019 | 06:33 PM
Default MSD distributor failure
I’ve had 2 new MSD 83606 mechanical distributors fail on my engine! What’s wrong here?
What do you recommend for another brand?
Cliff in maine
cdowjr is offline
Old 06-22-2019 | 09:56 PM
Tinkerer's Avatar
How did they break.
Sounds to me like maybe it isn't installed properly.
The only part I have had fail is the gear wearing out.
Tinkerer is offline
Old 06-22-2019 | 10:35 PM
SB
x 2. What specifically broke on them ?
SB is offline
Old 06-23-2019 | 05:50 AM
Default Mad mechanical distributor
what broke? They won’t run my engine now!
I’m not sure how to diagnose it. Ran fine a little while with one new msd 83606 distributor then just quit. Absolutely would not fire I even fried a starter trying to get it to run again.
i replace with another fired right up ran 5 minutes then quit!
I’m building 2 motors so I have 2 of everything.
i believe it’s possible for an ignition to spark but not be strong enough to run an engine I’ve seen that before.
how do I test things?
This is a plug & play distributor no ignition box needed.
How do I test a coil? What are the odds of both of my new coils failing? I say slim!
how do I test the ignition modular inside the distributor? And what are the odds of two of these failing?
Your help is greatly appreciated
cliff in maine
cdowjr is offline
Old 06-23-2019 | 09:05 AM
whats the voltage going to the distr.?if its low it could burn it out
sutphen 30 is offline
Old 06-23-2019 | 12:18 PM
Have you confirmed the dist is still turning (while cranking) after it "died"?
zz28zz is offline
Old 06-23-2019 | 08:14 PM
SABER28's Avatar
M S D, my spark died.
SABER28 is offline
Old 06-24-2019 | 07:36 AM
Wally's Avatar
Were doomed!
May Spontaneously Die
-Wally
Wally is offline
Old 06-24-2019 | 06:08 PM
SABER28's Avatar
haha ,thats a new one!
i cant believe anyone buys their products anymore, so much better choices out there.
SABER28 is offline
Old 06-24-2019 | 06:24 PM
I’m eager to jump ship what do you recommend???
im sick of this problem!!
Help!
Just want a simple system that works!
Cliff in maine!
cdowjr is offline
