500efi Rough Idle @ Warm >
Old 06-27-2019 | 10:34 AM
  #31
did you replace the ignition module ?
i swapped it with the other engine...no dice. Same issue.
1MOSES1 is offline
Old 06-27-2019 | 10:37 AM
  #32
F-2 Speedy's Avatar
what about ground all tight, I know the engine and I think the efi harness have large ground wires on them
F-2 Speedy is offline
Old 06-27-2019 | 10:49 AM
  #33
can check but these engine have two grounds for redundancy...
1. To primary ground
2. Both engines tethered together
1MOSES1 is offline
Old 06-27-2019 | 11:12 AM
  #34
F-2 Speedy's Avatar
there are multiple grounds on the harness
Old 06-27-2019 | 12:02 PM
  #35
Thought you meant main engine grounds...I have a manual, I’ll check out harness grounds.
1MOSES1 is offline
Old 06-29-2019 | 02:43 PM
  #36
It was pressure regulator...thanks everyone!!!
1MOSES1 is offline
Old 06-29-2019 | 03:38 PM
  #37
BUP
who lead the horse to the water on the phone calls here I got to get some credit here a tad yes or no ? - always check fuel pressure ESPECIALLY on new rebuilds and install new filters once per year whether one uses their boat or not.
a decent fuel pressure tester is maybe 30 to 50 bucks - cheap tool to have for whomever works on their own apps
at spring commission always check fuel pressure after lay up. Fuel pumps and regulators can go bad just sitting idle for months and is not uncommon for that to happen
BUP is offline
Old 06-29-2019 | 08:10 PM
  #38
BUP
past preach and should be done regardless and for rebuilds to prevent issues right out of the gate. Posted this almost a year ago. if you work on boats buy one before you get after it .
On the cheap tool for the boat owner
BUP is offline
Old 06-29-2019 | 10:07 PM
  #39
Originally Posted by sutphen 30
sounds like fueling at idle or it has a touch of reversion.really need a scan tool and some way to measure fuel pressure,you don't have a crank sensor,you do have a pickup coil inside the distr.
glad its fixed and not reversion.
sutphen 30 is offline
Old 06-29-2019 | 10:45 PM
  #40
hahahaa sounds like you were really banking on reversion lol
1MOSES1 is offline
