Oil pump failure >
Oil pump failure
Oil pump failure
Old 07-05-2019 | 01:42 PM
  #31
I just re-read my post - to be clear, I wasn't stating that your engine was cavitating. Specifically directed towards the hacked up cobbled together engine b4 it ate itself up.
Hope you get it squared away...
speicher lane is offline
Old 07-05-2019 | 02:06 PM
  #32
Here’s pictures of the dist. The tang doesn’t look beat up at all. Do you think that the wear marks on the gear are to low?
Melbatoast is offline
Old 07-05-2019 | 02:10 PM
  #33
I’ve also grabbed the tang with needle nose and tried to twist, pull, wiggle it but it doesn’t budge
Old 07-05-2019 | 02:42 PM
  #34
F-2 Speedy's Avatar
What distributor and intake are they, did you check the clearance on the oil pickup to pan ? pump might be cavitating if its to close to the pan, spinning it on a drill is much faster than at idle.
F-2 Speedy is offline
Old 07-05-2019 | 02:48 PM
  #35
its a msd I can’t give the model off the top of my head. The intake is a edelbrock rpm air gap. I haven’t check clearance on the oil pick up it’s a milodon pan and they’re oil pick up. I use the same set up pan and pick up on another motor with no issue. Not ruling that out tho
Old 07-05-2019 | 03:57 PM
  #36
14 apache's Avatar
The tang is beat up it is not engaged enough that's why there is no oil pressure. It needs a slip coller distributer. The tang is rounded over on the drive side
14 apache is offline
Old 07-05-2019 | 07:15 PM
  #37
Worked until the metal fatigued, rolled over, then poof - game over?
Makes sense to me.
Baja Rooster is offline
Old 07-05-2019 | 07:19 PM
  #38
14 apache's Avatar
Makes sense to me.
yes. you can evin see it's driving low on distributer gear.
Old 07-05-2019 | 08:07 PM
  #39
SABER28's Avatar
this is the only explanation that makes any sense. good news its easy to fix.
SABER28 is offline
Old 07-05-2019 | 08:12 PM
  #40
14 apache's Avatar
it's easy fix but have to hope he didn't damage crank and bearings.
