power steering pump /hydraulic steering issue HELP >
Old 07-03-2019 | 11:52 AM
Wobble's Avatar
SORE MEMBER
if you have an inline filter, try bypassing it. My system came with one on the pressure side and was a major restriction, magnet in the reservoir is sufficient.
Wobble is offline
Old 07-03-2019 | 12:24 PM
thank you I will try that for sure , was told that something may need to be drilled to increase flow? anyone have any idea what this might be
daniel475 is offline
Old 07-03-2019 | 01:02 PM
Wobble's Avatar
SORE MEMBER
where the high pressure line comes out of the pump there is a big nut, the oriface is part of the assy that comes out with the big nut.
Modifying your Power Steering Pump - GM Truck Central
Wobble is offline
Old 07-03-2019 | 01:12 PM
TomZ's Avatar
I sent the same thing over to Daniel via PM. I had to do this on my Latham system.
TomZ is offline
Old 07-03-2019 | 02:24 PM
F-2 Speedy's Avatar
dual rams , single motor , yes it look a lot to initially prime it , the steering WAS working then my old merc power steering pump leaked so I thought I would replace it which I did , filled the new automotive one pretty much to the top obv could have been a little air in there , gonna try cracking rams at the back to see if there is any air ....
the rams are under pressure from the helm at rest so dont get a face full.....
F-2 Speedy is offline
Old 07-03-2019 | 02:38 PM
sounds good thanks for the advice gonna rip it apart AGAIN and drill the hole bigger , so ram hard over then crack the line at the back on the ram that's fully extended , im really losing patience really hope this fixes it
Old 07-03-2019 | 02:58 PM
TomZ's Avatar
You'll love it when it's done. I did a poker run in my 311 last weekend... what a difference! The washing machine pretty much had no affect on the boat's direction, point and go! We also road back home about twenty-five miles across the Chesapeake Bay.... sitting at the helm barely even working the wheel... straight as an arrow!
You'll get it right Daniel.
TomZ is offline
Old 07-03-2019 | 02:59 PM
F-2 Speedy's Avatar
Is the steering running through a cooler before the fluid returns to the pump, where are you located, maybe someone on here could help out
Old 07-03-2019 | 03:04 PM
located just outside of Vancouver British Columbia Canada , in Gibsons BC , I believe it is yes what are you thinking ill have to double check that , count down is on leaving next week for lake chelan poker run ! really hoping I get it figured
Old 07-03-2019 | 03:11 PM
F-2 Speedy's Avatar
Well, BC is just a bit far from KS , personally I think there's air in the system, took me three tries to get my ITS jammin.....like TomZ said when its rite you're stylin like a Caddi
