Mercruiser Crank No Start With Code 41 >
Old 07-04-2019 | 09:09 PM
try disconnecting the tach.might try bypassing the ignition switch by jacking 12v into the purple wire then try starting it.
sutphen 30 is offline
Old 07-05-2019 | 09:52 AM
The ignition switch was replaced and tests properly. I’ve tried everything with the tach disconnected as well as connected. There is no kill switch and the neutral safety switch tests properly....
Nick
nicktrover is offline
Old 07-06-2019 | 12:10 PM
BUP
have you tested for spark ?
Module
pick up coil
knock sensor
BUP is offline
Old 07-14-2022 | 07:11 PM
Default Having same problem
Nick please tell me how or if you solved this problem. Having the same issue and also pulling hair out!
Sham is offline
