Speed limited Blackhawk >
Old 07-08-2019 | 07:54 AM
Originally Posted by TomZ
Story of my life!!
Cheaper and more effective than a therapist
speicher lane is offline
Old 07-08-2019 | 07:57 AM
TomZ's Avatar
Agreed! Best money I’ve spent!
TomZ is offline
Old 07-08-2019 | 11:45 AM
By rights, the fuel tank should have been drained and system flushed (4-5 years little use).. dirty fuel only creates bad burn and detonation.... and headaches.
What condition is your ignition system in - plugs, caps and wires? they will rob you rpm on top of the weak fuel
the cap, plug and wires look good. Plugs overall good. I did check compression and a few cylinders were around 140....but nothing really wrong.
Once i I know the overall operation of the engine is good (from a sensor/wiring, etc i plan to power up the engine (this winter). Nothing worse than carrying a problem into a new build. I suspect any overall speed concern or gap will go away afterwards!
sandslot is offline
Old 07-08-2019 | 11:46 AM
Originally Posted by Rookie
Prop size? What did it usually run? This setup has performed properly in the past?
yep, nothing has changed from original..
sandslot is offline
Old 07-08-2019 | 11:48 AM
You really should get those injectors out and cleaned/replaced. The quickest way to burn down one of these MPI set-ups is running with clogged/bad injectors. It’s a fairly easy job to do.
Reach out to oso member BUP. He can help you out with the injectors.
cleaning the injectors sounds like a good thing to do.... especially since the boat is running better each time I run it.
who is BUP
sandslot is offline
Old 07-08-2019 | 11:49 AM
for or some reason this link did not work...I’ll try later on my desktop
sandslot is offline
Old 07-08-2019 | 02:37 PM
B.O.A.T = Bring out another thousand...starts the season for maintenance, then turns into the fuel bill
Those are 1970’s prices. Now it’s B.O.A.T.T.
Baja Rooster is offline
Old 07-10-2019 | 03:47 PM
Do this ^^^^^^^ 10,000% correct. Dare you to ask me how I know haha. The fuel injectors in these Merc motors are horrible, especially when laid up for long periods. I have same motors and an injector that flowed 24% low roasted my piston and ruined my day and month. Engine even "felt" like it was running "good" too!
Gimme Fuel is offline
Old 07-10-2019 | 04:46 PM
Thank you for the input..... I’ve decided I’ll just replace them. Any particular brand or outlet?
sandslot is offline
Old 07-10-2019 | 06:38 PM
getting them cleaned and flowed is better than new. atleast you will know for sure they have been tested good. new ones are just supposed to be good.
beaver 3 is offline
