-   -   Supercharger water intecooler feed line (https://www.offshoreonly.com/forums/general-q/361741-supercharger-water-intecooler-feed-line.html)
es99eliminator 07-13-2019 05:51 PM
GPM=I don't see allot of pressure coming out of the outlet hose. My setup doesn't see a lot of water pressure on the gage. I rebuilt the sea water pump earlier this year. Engine stays cool .
GPM 07-13-2019 09:18 PM
You might want to put the T after the sea water pump so you are pressure feeding the cooler, where is the pick up in the drive ?
es99eliminator 07-14-2019 09:56 AM
GPM- yes bravo 1 drive, T is in the pressure line off the seawater pump
I pulled the thermostat back out and will run the boat today...I'll let you know temps when i get back..
r,
E
es99eliminator 07-14-2019 04:08 PM
GLM- Took it out today and some magic must of happened between changing the alternator and removal of the thermostat.
MAT temps came down and the cooler was flowing alot better. Temps still got to around 140F after WOT runs but, cooled down.
No surging whats so ever. Boat ran fantastic. Best its run in a while.
checked inter cooler discharge while running and pressure increases as rpm comes up.
As most boosted situations it probably could use a little bigger cooler. or one that flows more.
r,
Eric
GPM 07-15-2019 10:11 AM
Pro Charger doesn't want you to run a thermostat, the M4 cooler isn't the best. If your drive has a low water pick up similar to the Imco you can extend the opening to get more water to the motor.
es99eliminator 07-15-2019 02:12 PM
GLM- Yes I have the low water pickup..how do i extend the opening?
R,
E
GPM 07-16-2019 09:32 PM
On the Imco you can make the slot longer not sure on the Bravo
