Oil Temp Sender Location >
Old 07-14-2019 | 12:04 PM
Scarab28's Avatar
Default Oil Temp Sender Location
Gen VI Dart block - I moved my Oil Temp sender to the plug at the rear top of the motor. It's now reading low oil temp there (110). Is this a bad spot for the sender. I did read not to install it in a dead ended location.
Scarab28 is offline
Old 07-17-2019 | 06:12 AM
I always ran them in the oil filter mount
ezstriper is offline
Old 07-17-2019 | 06:37 AM
Mines on the oil filter mount. Runs high though but think its the senders. When I shoot it with the temp gun its always sitting within reasonable range.
sleev-les is offline
Old 07-17-2019 | 08:23 AM
SABER28's Avatar
you should be measuring that oil temperature in the pan , but thats not always the easiest place to get to.
SABER28 is offline
Old 07-17-2019 | 08:30 AM
F-2 Speedy's Avatar
and you put in a dead end spot, oil pressure sender is fine there, oil temp sender needs to be in the oil flow before the cooler.
F-2 Speedy is offline
