Psa
Old 08-04-2019 | 11:06 AM
Never run my junk 7.4 lx mpi's under 1/4 tank, nor any other vehicle.
Tractionless is offline
Old 08-04-2019 | 11:14 AM
I've had the same failure on some old blow thru carbed turbo motors years ago ( till I got them dialed in). Happens quickly and cuts a perfect groove. Lean motors usually make more power until... Good luck.
PARASAIL941 is offline
Old 08-04-2019 | 12:53 PM
Originally Posted by SABER28
to me that looks too smooth to be a casting break. ive replaced 20 plus engines that broke a mount or boss in a automobile collision and they always are very rough on the surface. how deep is the gouge?
I/2 an inch or more. It is not entirely smooth, it almost looks like it let looses and the heat took over. You can see casting like a break with the surface starting to smooth over like melting. It certainly could be burnt but the block is perfect including the deck and that is the only damaged. we even pulled the valves and they are perfect. Even the adjacent Intake. I get the Inconel not burning.
RBeyer is offline
Old 08-04-2019 | 04:12 PM
SABER28's Avatar
yes, now that i think about it why didnt the block burn up too? i could see if the heads were aluminum they would go first.
this is why i went with big (557) cube n.a. engines. big , fat , and lazy engines that make good power without trying hard. those blower motors require everything just right and you know fuel quality can be an issue.
SABER28 is offline
Old 08-04-2019 | 07:25 PM
Rookie's Avatar
I had the same failure in my old Merc 420 NA. Brought the head to the machine shop. They welded it up, machined it smooth, put a straight edge on the block, new gasket and it was good to go. The block doesn't get torched because the block has cooling. As stated earlier, the head has a hot spot there.
Rookie is offline
Old 08-04-2019 | 07:47 PM
Full Force's Avatar
This^^ block is cooled that's not a casting issue, any casting issue would surface right away, lean issues melt thigs very fast, seconds...
Full Force is offline
Old 08-05-2019 | 12:04 AM
It was, maybe 20 seconds.
RBeyer is offline
Old 08-05-2019 | 05:17 AM
Full Force's Avatar
All it takes..
Old 08-05-2019 | 05:47 AM
Tinkerer's Avatar
If a piece had broken off you would have damage to the head and cylinder from the piece ratling around in there.
You ran lean.
Tinkerer is offline
Old 08-05-2019 | 01:58 PM
SABER28's Avatar
You ran lean.
yes you would think that chuck would cause damage on the way out. that is amazing to me that it cut right through like a torch. learn something everyday.
SABER28 is offline
