Replacement horn...is nothing simple? >
Old 08-09-2019 | 02:42 PM
I get 13+ volts out of each wire when the horn button is depressed.
Might be missing a ground if they are both hot
AllDodge is offline
Old 08-09-2019 | 04:33 PM
Is your horn listed here?
Sea-Dog : Quality Marine, Industrial and Rigging Hardware
underpsi68 is offline
Old 08-09-2019 | 04:36 PM
Yes Sea Dog brand
F14A water jet is offline
Old 08-10-2019 | 06:09 AM
TomZ's Avatar
I use a handheld air horn....
TomZ is offline
Old 08-10-2019 | 08:36 AM
On a side note. I LOVE the title of your thread, I too find the easiest tasks wind up becoming half day ordeals and have coined the saying. "Nothing Ever Easy."
Tractionless is offline
Old 08-10-2019 | 01:50 PM
Originally Posted by underpsi68
Yes...downloaded, thanks!
Old 08-10-2019 | 01:51 PM
I got air too...but just had the opportunity to TRY to make these work.
Old 08-10-2019 | 04:57 PM
Two Questions - have you identified which grey wire is your Ground and which is hot in order to properly wire the horns?
2) Did you attempt to adjust the original horns? ( remove cover and there is a phillips screw with a locking nut on the horn... tun in or out to change pitch of the horns?
speicher lane is offline
Old 08-11-2019 | 02:39 PM
So, I deduced that the horn button might be intermittent so I got a replacement at the home repair store. While removing the old button I touched two hot wires that popped the horn circuit breaker. When I reset the breaker (which I had manually pulled and reset at least 3-4 times) I noticed a distinct "click" and the original horn button and new replacement dual horns started working as advertised.
I'm guessing that the contacts in the circuit breaker were contaminated???
Anyway, horns are working and thanks to all for the help.
Tom
Old 08-12-2019 | 01:26 PM
True, nothing on boats is simple or straightforward, lol.
I have a 20 year old freshwater Baja with a ton of electrical gremlins. Their wiring was of minimal quality to begin with and add in normal use and typical corrosion after time and you’ll have the issues that you’re having now. I completely stripped the bilge and rigged it with new equipment, and will redo the rest of the boat this winter as well.
Baja Rooster is offline
