Valve train noise 525 efi after top ends
you said one of your engines, twin engines, one is stock and the other one is not ?
Easiest way to do it is with the intake manifold off. Then you can actually see when the lifter compresses.
yes, I'm only doing one engine at the moment, had a pushrod pop off a rocker due to a valve stuck in the guide. Trying to get it back on the water asap so I'm not wasting the entire short summer here in Vermont.
I used the polys that came with the rockers, the center pin on the harlands is recessed, the installed height of the poly is lower than the top of the rocker arm. I'm gonna run it today with covers off and see what happens.
just curious why you didnt stay with the OE lifters and push rods unless the Dart heads didnt allow for it
Had two 500efi’s refreshed including new lifters. Had issues with both motors from the get-go. Lifters did not want to stay pumped up. Thing sounded like a tractor at idle. Played with pre load and oils. Nothing worked. Ended up replacing with Johnson’s. Problem went away and haven’t had an issue since *knock on wood*
