Merc 6.2
Old 08-18-2019 | 07:49 PM
Default Merc 6.2
Has anyone seen these before ( it’s not a butt connector) it is wired inline to the thermostat sending unit. It appears to change the temp reading by 10 to 15 degrees. It’s on a 2006 mercruiser 6.2. Thanks
98outlawse is offline
Old 08-18-2019 | 08:16 PM
measure it w/ an ohm meter and see if it has a resistance value.
sutphen 30 is offline
Old 08-18-2019 | 08:21 PM
It might be used as a pull up resistor.
underpsi68 is offline
Old 08-18-2019 | 08:23 PM
The problem is it’s broke in half, so I won’t be able to pull the ohms
Old 08-18-2019 | 08:28 PM
Cut the covering off. See if it is a resistor inside. If so the resistance will be the color code on the outside.
It might be 2000-2200.
Old 08-18-2019 | 08:59 PM
So this resistor will pull the temp reading down on the gauge to match what the Rinda shows it’s reading?
Old 08-18-2019 | 09:03 PM
BUP
^^^^^^^^^^^ Underpsi posts --- Bingo .
BUP is offline
Old 08-18-2019 | 09:06 PM
So where can you get them, or is it possible to change to a different temp sending unit and eliminate the resistor? And thank you.
Old 08-18-2019 | 09:12 PM
BUP
U need to post your engine serial number and which 6.2 do you have
BUP is offline
Old 08-18-2019 | 09:20 PM
Thank you, I will get the serial number, I’ll probably reply with it tomorrow unless I come up with it on some paperwork work I have here.
