COG drive help needed >
Old 10-04-2019 | 11:45 AM
Default COG drive help needed
I need to set up my procharger with a cog drive. Has anyone here done that with a 496 based block? I have stock serp and my charger is extended past that. So I need cog drive for my blower wiht the right offset and crank drive that will bolt up.
Any help would be appreciated.
Cerberus66 is offline
Old 10-04-2019 | 02:55 PM
GPM
Just curious, why are you running a cog drive
GPM is offline
Old 10-04-2019 | 03:47 PM
Advisement from Arizona Speed and Marine. if i want to step up to 10-12lbs. There have been some recent advances in belts and drives so i have bought a new gates rpm belt and pulleys to push up to 7-8lbs from barely 2.9
Old 10-04-2019 | 04:21 PM
GPM
I was just curious, I could run 16 to 18psi with a 12 groove.
GPM is offline
Old 10-04-2019 | 04:26 PM
THats great news to hear thanks a bunch. what are you running? I have a 3.4 pulley and 6.9 crank pulley
Old 10-04-2019 | 04:37 PM
GPM
I was running an M-5, I think the crank pulley was 7 and I know the blower pulley was 4.5.
GPM is offline
