Winterizing Question >
Old 11-04-2019 | 06:25 PM
Default Winterizing Question
Hello,
I have a 86 scarab panther, 7.4 mercs. Keep in a lifted slip and had originally planned to pull boat for winter and drop at marina last weekend to winterize, decided to leave in slip for winter under cover and not clog the driveway up. Needless to say marina can’t winterize til Thanksgiving now. We live in Virginia but looks a little colder than normal. Calling for 45/25 and 45/27 this weekend, then a few more nights in 30/28 range next few weeks.
Marina told me unless it stays below freezing solid for a day or two, no worries. Thoughts??
Dboss33 is offline
Old 11-04-2019 | 06:37 PM
jeff32's Avatar
Agreed! But keep an eye out on the thermometer!
if you can put a light bulb in the bilge!
jeff32 is offline
Old 11-04-2019 | 06:47 PM
5 hours at 23F (-5C) will freeze and prob split.
There is another thread on here about a thermostatically controlled/ C.G certified bilge heater - don't recall price but cheaper than engines if the threat of a freeze is there.... or drain your cooling systems to minimize damage
speicher lane is offline
Old 11-04-2019 | 07:28 PM
What does it take to freeze & crack an engine block?
24* for 24hrs is the general rule.
ICDEDPPL is offline
Old 11-04-2019 | 07:33 PM
F-2 Speedy's Avatar
Id pull all the plugs, who can predict the weather
F-2 Speedy is offline
Old 11-04-2019 | 07:45 PM
i have a couple of these,dont remember what they cost but they work well.
mike tkach is offline
Old 11-05-2019 | 01:06 AM
If those are the actual low temps, they will only be that low for a couple hours and you'll be fine.
If it changes and they're gonna be lower, I'd do the lightbulb option or just drop it in the water. The water temp will be significantly warmer than the air temp.
Griff is offline
Old 11-05-2019 | 07:21 AM
Another thread on this and I decided:
https://www.boatownersworld.com/cafr...-400-watt.html
Xtreme Small Boat Heater - 300 Watt
F14A water jet is offline
Old 11-05-2019 | 08:32 AM
Mentalpause's Avatar
You should be fine at those temps, especially this time of year over the water while the water temps are warmer than air temps. This time of year at LOTO many marinas will tell you sustained temp around 20 for 24 hours given the water temps are still around 60. Testing their theory would make me a bit nervous, but the light bulb or 2 will work for the next 3 weeks.
Mentalpause is offline
Old 11-05-2019 | 10:52 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Just put a 100W bulb in a droplight in the bilge. These work great for that task. I always went with two in case of a bulb failure.
Sydwayz is offline
