Arizona Speed & Marine EFI's
Getting cold here going to winterize the boat this is an issue now to take up in the spring ....I found on the r/s rear end of the throttle valve in a recessed hole an alan head screw to manually advance or retard idle
I have one more shot to run engines before winterize ........I'll go through all the steps suggested.........Thanks all!
Thats not really how idle is set, that positions the throttle blades so iac count has enough.left to recover when you put it in and out of gear but a low enough iac # to NOT go to zero warmed up and idle too high. If this is a new problem (this uncontrolled high idle) and it was fine at one point, if you start pissing with that when problems actually a vacuum leak you will need to chsnge it back or iac will have no control once you fix actual problem, Smitty
No it doesn't mean both have a vacuum leak. The high idle motor likely does or the throttle blades/linkage are not working correctly. Fix this engine/problem first, THEN we can address the other motor that stumbles.
Your original post said it was the port engine with the high idle???
Unless PVC has gone bad or hose detached.....but being blocked off ?...wouldn't that be an international move?
