Intake
Old 11-28-2019 | 02:59 PM
Originally Posted by articfriends
Edelbrock perfomer rpm is good, the zz502 gm version is essentially the same. In a dyno test here a year and half ago a friend had a 502 w edelbrock 290 oval port heads, pretty small cam. He bought a vic jr as they seem to be popular, afrs on a few cylinders like #8 were over 2 points leaner (carbed). motor peaked below 5500. We bolted a ported standard performer intake on and picked up somewhere around 20 to 30 ft lbs tq and almost 10 hp (on top), #3 cyl at wot was over 2.5 points leaner than the average of other ones though. We took it off and put agm zz502 intake on which looks identical to me to a perfomer rpm and picked up even more tq, thruout whole range and a small hp gain on top. down in the 3600 to 4500 range I think overall he picked up around 50 ft lbs over open plenum. I will say this though, the vic jr was bolted on out of the box and had smaller ports than the heads , the zz502 intake was stock too, Smitty
My ZZ502 engine came with The Eddy Performer RPM and the thing was a torque monster straight from idle and pulled hard up to 5600 until I re-propped.
Baja Rooster is offline
Old 11-28-2019 | 09:47 PM
gmhdfan's Avatar
Chevy-Harley fan
We ran/tested the ported standard performer intake because my dyno partner had one from a motor home laying on shelf at his shop (so it was free). anything it does for most part, a performer rpm does better. Because we saw 15.5-1 afr on #3 cylinder at wot when others were12.5 to 13-1, I personally would never use one on something that gets held at WOT, the cylinder to cylinder distribution was much better on the performer rpm in my experience, Smitty
Was wondering if you ever did any dyno with the old twisted Torker intake and how the AFR were?
Pete
gmhdfan is offline
Old 11-29-2019 | 07:23 AM
articfriends's Avatar
No I havent,i only got my dyno and data acquisition, 10 02 sensors etc up and going here 4 1/2 years ago and have only dynoed about 10 or 12 carbed BIG BLOCKS, none have had that intake, the rest have been EFI, Smitty
articfriends is offline
Old 11-29-2019 | 12:57 PM
BUP
just be clear carb set up ? is the route your going for sure ? I did not read all the post here.
I am fan of the Brodix Alum heads. and they have couple of new intakes on the market that have done well.
BUP is offline
Old 11-29-2019 | 04:45 PM
With stock zz502 roller cam?
JaniH is offline
Old 11-29-2019 | 04:55 PM
GPM
[QUOTE=gmhdfan;4716672]Was wondering if you ever did any dyno with the old twisted Torker intake and how the AFR were?[/Q
We tried one on a 468, it was basically a turd compared to the RPM airgap. Way less torque across the board with no more HP all the way to 6400 rpm. A/F ratios were all over the place, it may work better on a different motor.
GPM is offline
Old 11-29-2019 | 05:06 PM
Just get what everybody knows is correct and be done with it. Air Gap dual plane, you are not building a 1,000hp offshore boat.
GLENAMY 242SS is offline
Old 11-29-2019 | 06:55 PM
Yes. Also with Comp Cams Magnum rockers that freed up some rev as well.
Old 11-30-2019 | 02:10 PM
Yes carb setup. Im running the merlin 320cc runner heads on a 496. Im still looking for a cam but figure I will end up with something like the merc 525 or crane 731 cam.
27formula is offline
Old 11-30-2019 | 03:14 PM
SB
400 million years ago, I tuned a few different cars at the track with those intakes. A low compression 454 and a few higher compression 454's.
The intakes sucked bad. But, they fit under some low hood heights and we found out that was the only reason they where made.
This was before Eddy RPM days, but Dart had had just come out with their single plane intakes and that was that. Weiand dual planes or Vic Jrs or Holley Strip Dominators or Darts for those cars.
SB is offline
