Hard warm start vintage BBF
I would replace points and condenser just cause they're old. Ballast is probably OK but should be measured and inspected visually. If it's still doing it, double check for fuel leaking inside carb bores with throttle blades wide open immediately after shutdown. Have the air cleaner off before shutdown and have a bright flashlight light ready. That's what it sounds like to me. Check float levels on the water.
BTW, you stated you have to crack the throttle to start, which helps when flooded.
Pumping the throttle only helps if running too lean.
Shouldn't have to do both.
When it fires there is a lot of steam and some black/brown smoke which makes me wonder about water in the combustion chamber. I would think if water was getting in there I would have some difference in the way the starter turns the engine over but there seems to be none. Oil looks new with no contamination.
I can't get parts for the distributor. Probably going to go with a pertronix flamethrower III or DUI.
The cables are old but seem reasonable. They were on my list to replace with some custom length ones. The starter turns the engine over very strong when warm. No difference when cold.
You didn’t fully answer my questions. What do you have the choke wired to?
Also, so in that freezing weather, it started fine when engine was cold ?
could have choke wire on the wrong side of the ballast.seen that a few times.plus,is there a wire from the other small post on the start to the coil plus,,this is there for full 12v when starting only.
not getting clear info. Oh well.
Positive wire to choke is from the side of ballast where the power goes in.
There is a wire from the starter that goes to the out side of the ballast.
The engine started how it typically does when cold.
The wire to the positive side of the coil comes from the out side of the ballast.
I would adj the choke all the way open and remove the pos wire, with a holley should start fine with no choke, see what that does, best thing you can do ign wise is a DUI HEI, also might try a plastic heat insulator spacer under the carb in case its heat soak
