Bravo to #6 conversion? >
Old 12-19-2019 | 04:39 PM
Thanks Kwright. I’ve followed your re-rig thread, it’s been great! I didn’t realize your boat was bravo before. I’ll have to go revisit it, I may have jumped in after that part. Guys like you who are open to share their experiences are what make a forum like this great.
IGetWet is offline
Old 12-19-2019 | 04:44 PM
F-2 Speedy's Avatar
Dont you have a 25 OL now ? what size and power do you want to move up to
F-2 Speedy is offline
Old 12-19-2019 | 05:12 PM
Yes 25 outlaw. 38-42’. 525s would be a good start.
IGetWet is offline
Old 12-19-2019 | 06:49 PM
I am just starting this process so not a lot of help to you. I've had the help of some very knowledgeable people. My boat started life with 6's so many parts are still there. XR's were added at one time so I am just going back. If your starting from scratch someone above stated that find a boat already rigged but no power might be an option. Having looked at a bunch of options this would be the easiest way to go. every once in a while you will see one for sale. And as for the 3, 4, and 5 ssm. I saw several of them all inclusive in, I think, Ohio for sale recently at a pretty good price. On this i could be wrong so verify but I've read the 3A's and the 5's are better with a bigger prop shaft. These too will require a trans. And the prices i've seen on a few aren't a whole lot higher than an XR set up. Again, I am not saying this is all fact but just what I've read.
TDSracing is offline
Old 12-19-2019 | 07:19 PM
You could go to the Sutphen forum and check out any 39's for sale!
benjen is offline
Old 12-19-2019 | 10:13 PM
With all new parts, you'll have close to a 100k in a Bravo to SSM6 conversion. SSM6's have their own built in hyd steering system.
Griff is offline
Old 12-20-2019 | 05:26 AM
Phuck that. Factor in your time invested also. Just buy a boat with 6's if that's what you want.
Drock78 is offline
Old 12-20-2019 | 06:44 AM
your pretty close, after drives and transom assemblies, you will have one drive line adapter, one plug in kit. Transmissions, bell housings, drive plates, drive shaft, driveshaft guard, tie bar, props, oil and trans oil cooler lines. Then a new helm pump for steering, even though the ITS has integrated steering the steering rams are much smaller than the 6 drives. You will also need a steering protection valve. Thru hull water pickup and sea strainer. If you go with the dual cooler bell housings, you will need rear mounted starters, and also flywheels with ring gear on the face side. It definitely is a ton of work that is for sure!
KWright is offline
Old 12-31-2019 | 09:59 AM
Why would the 3.4.5's be cheaper? Doesn't the transom still need filled and cut, plus of course motors moved forward.
How easy is it to find parts for 5's?
I dont think the transom needs to be filled, just re-cut and drilled for #6s. May have to dowel a few of the drilled holes from the Bravo
JRider is offline
Old 12-31-2019 | 10:04 AM
Alot easier to put Imco SCX -4’s on with #6 prop shafts.
302Sport is offline
