Let there be light
Could also be a combination of a few things. Lens clouding from time, needles and numbers fading, mediocre wiring from new which has now built up resistance, contacts inside switch corroding and adding resistance. I've had the contact points between the spring clip and glass fuse get oxidized and needed to clean it to get the bilge pumps to run at full speed. Lots of basic but easy troubleshooting. Odds are they make an LED replacement bulb that will be considerably brighter than a filament bulb
Straight bottoms and flat decks
[QUOTE=Jojoegen;4719171How do I test for a bad ground? I guess I could start there[/QUOTE]
I would run a 14ga or larger test wire from the batt ground terminal and connect it to the dash ground and see if the lamps get any brighter.
Look for wiring that doesn't look original. When I first got of of my boats, found someone had powered the cigarette lighter from the clock with ~22ga wire. Spot light didn't work very well.
I'd get a digital multimeter capable of volts/ ohms which can be found cheaply and will allow you to check everything out. See what the voltage is right at your battery, see what it is at the fuse block and at the gauge itself and anywhere else. There is likely a strip of metal in or near the dash wiring with lots of black wires going to it. Frequently smaller black wires coming directly from the components with one or two larger black wires running back the battery/ engine compartment area. You should be able to check all your grounds right at that strip. Use the ohm meter or a test light to check them.
Here's mine. The black wires are all my grounds. I expect you have something similar. I find it easiest to test them with a test light. If anything seemed suspect I'd switch to the meter.
