Electric fuel pump? >
Electric fuel pump?
Electric fuel pump?
Old 02-09-2020 | 09:21 AM
Default Electric fuel pump?
Hi, I just burnt out my carter p4070 electric fuel pump when I got to the last 5 gallons in the tank.
does anybody have a recommendation for a fuel pump to pull fuel from my tank, through the separator then to the carb.
i cannot place below tank because the tank is sealed below the floor boards.
any advice is greatly appreciated. Almost considering the mechanical version....... don’t need issues in the ocean.
thanks, -Randy
rc415 is offline
Old 02-16-2020 | 10:50 AM
I have been running the std Holley blue pumps just like that for 5-6 years now...
ezstriper is offline
Old 02-16-2020 | 12:13 PM
BUP
carter again - there is one not painted / coated and there is one that is.
I would have to check the numbers cause I have them in stock and they are not 4070 models.
Many repower non OEM engines and indmar and marine power use these pumps
BUP is offline
Old 02-17-2020 | 07:25 AM
Weldon 1100A
larose481 is offline
Old 02-18-2020 | 04:12 PM
Originally Posted by larose481
Weldon 1100A
Hi There, so I installed a Facet Dura Lift pump. 110" dry lift. its amazing thus far. ran it on the hose for 45 mins. Highly recommend thus far.
very quiet. well built.
rc415 is offline
Old 02-18-2020 | 04:39 PM
GPM
Some people would pull through a 100 micron stainless pre filter then push through something like this before the carb, https://www.fstperformance.com/
GPM is offline
Old 02-18-2020 | 04:50 PM
thanks, -Randy
Would be good to know what the pump is feeding to provide a better answer. If you have a stock motor then use the holley Blue or replace with same. Do check specs on the pump and if it produces more then 7 psi (if carb motor) will need a inline regulator
If you have a higher performance motor may need some of the others folks have been mentioned.
AllDodge is offline
Old 02-19-2020 | 11:21 AM
SB
thanks, -Randy
You've been using non-USCG marine approved pumps if that matters or not to you.
https://www.pegasusautoracing.com/pr...asp?RecID=9705
Amazon Amazon
SB is offline
Old 02-19-2020 | 11:53 AM
BUP
USCG or any boat inspection on the water ways would tow you in with that plastic bowl on the facet fuel pump plus either fine you or warning ticket about that pump. . That is not legal for any enclose engine compartments period.
it only pumps 33 gallons per hour.
BUP is offline
Old 02-19-2020 | 12:00 PM
BUP
I would wonder if his app for an Weldon is like way over kill since he had a carter. And the price of the Weldon for some would never be considered. Keep in mind there is only one Weldon pump that is USCG approved as well. But many use Jim pumps including myself.
BUP is offline
