Alignment still an issue >
Old 03-11-2020 | 10:14 PM
Have you tried turning the engine over at all? Could be your coupler is just stuck in one position. Put your alignment bar in and hit the bar with a rubber malet from side to side a couple times. Loosen you rear mounts and rock the engine around a bit. Retighten the rear mounts and then check your alignment with the bar. Something just may not be seated all thr way.
Steve
Katanna is offline
Old 03-11-2020 | 10:43 PM
ph1971. Thank's for the diagrams! I get what your saying. I can't take the engine out but I can raise it a few feet off the stringers. I will give it a shot. Thank's again!
BravoX1D is offline
Old 03-11-2020 | 10:57 PM
Steve
I tried everything you said and then some. The bar refuses to go in unless the block is off center. At one point it was dead on. This sure is a mystery!?
BravoX1D is offline
Old 03-11-2020 | 11:18 PM
Originally Posted by getrdunn
Sorry to hear about your issues. That sucks but certainly not the first time for something like this. Like phragle mentioned nothing truly square in a wooden or glass etc boat. I might not be getting a 100% but can you shim anywhere to find a happy medium. My biggest concern would be the potential stress on the side load of seals / bearings. I might have missed it but if you drop your transom mount bolts in place from what I understand is your engine is not parallel to your stringers resulting in not mating with the front mounts. If you can get the drive on without force is it possible to do as motioned above with shimming or offsetting forward mounts. Kinda funny I've used a drywall square myself in the bilge for various reasons over the years but typically leaves me scratching my head for reasons like phragle said.
My boat may very well have come from the builder that way. I did the entire engine compartment over so I will never know. My new stringers are of the same dimensions and very close to the original locations and everything looks kosher. I intend to try what ph1971 suggested. If I come to the conclusion my transom is off somehow, then shimming one side of the transom plate is my only option. Just for the record, everything is new except for the transom assembly. it was rebuilt. Thank's for the feed back!
BravoX1D is offline
Old 03-12-2020 | 02:23 AM
Wow, what an issue.. Regardless, seems the motor must be square to the TA so..front mounts must go where they want once motor square.
Pismo10 is offline
Old 03-12-2020 | 06:03 AM
what did you torque the transom nuts to?does it look like the transom may be crushing to 1 side?
sutphen 30 is offline
Old 03-12-2020 | 07:41 AM
I also have been scratching my head over your situation. Only other thing can come up with is check the fitment between the back of your block and the flywheel cover assembly (bellhousing in a car) . Make sure it is not somehow cocked or binding somewhere, perhaps something wedged between them (like the ground cable or a washer). The flywheel cover not mating properly to the rear engine block would produce this. Keep us posted.
GLENAMY 242SS is offline
Old 03-12-2020 | 12:42 PM
If I remember I may have torqued to 35. The inner transom is solid, no crushing evident. The coupler and flywheel housing were assembled out of the boat. I replaced the 2 pieces 3/4 plywood on the transom and glassed over it. I can't swear there is no deviation in my work. I'm trying to figure out how much of an offset in the transom plate would affect engine alignment. For example, what would 1/8" translate to at the front mount?
BravoX1D is offline
Old 03-12-2020 | 02:03 PM
What kind of power you running. My only advice would be to get measurements as ph1971 illustrated and would determine where the problem is. If it’s in your work **** happens but as long as your confident you have the bond and strength needed just adjust forward mounts accordingly and run it. Someone here might be able to determine whether you can shim the inner assembly and caulk. I have no clue on that but I’d say you might have some deviation in your work. Take your time and get it the best you can for safety and performance and go have fun.
Are all the transom bolts showing the same amount thread?
getrdunn is offline
Old 03-12-2020 | 04:59 PM
Hi. Power is 600 hp 502 built up from a GM crate short block. I usually go overboard when it comes to building anything. I would say my transom job should be reasonably uniform. Nothing about the transom plate looks weird or out of place. Shimming said plate would be very unorthodox, but possible. Side loading on the grease seal may be the only down side. I'm sure the gimbal bearing can compensate. I mite just say fork it, and move forward. I don't usually give up on something until every possible option has been exhausted. Happy boating!
BravoX1D is offline
