do I need aftermarket heads for blower application? >
Old 11-07-2002 | 07:02 PM
timucin's Avatar
Default do I need aftermarket heads for blower application?
I am a bit confused because there will be a boosted fuel/air combo. I think gm heads will be ok with that ?
am I right?
timucin is offline
Old 11-08-2002 | 08:16 AM
JimV's Avatar
If you want to make more hp you have to change heads or spend a lot of money porting your GM heads.
JimV is offline
Old 11-08-2002 | 06:48 PM
timucin's Avatar
JimV : we dont have flowbench etc here.and porting is very expensive in states.as you told buying aftermarket is the best solution
thnx
timucin is offline
Old 11-08-2002 | 08:24 PM
paradigm shift's Avatar
Just my opinion but I think it depends on how much HP you are trying to get. There are quite a few blower motors out there running with stock port heads. A blower is not a critical on head porting as a NA motor depending on how much HP you are trying to squeeze out of it. With that said a blower motor will make more HP with a great set of heads over a good set of heads everything else being equal no argument there. Look at how much a 500HP with a whipple will make with NO PORTING as an example. Just depends on how much HP you are looking for then you can plan the rest of you motor build sheet.
paradigm shift is offline
Chris Sunkin
30
09-08-2024 01:57 PM
cloudmaster_321
Do It Yourself, Boating on a Budget
13
09-08-2008 01:15 AM
homan
10
11-23-2003 07:55 PM
diveboy
7
02-25-2003 10:51 AM
