Supercharged starting hard
I would pick octane requirement over ethanol free 90. From 1999 - 2017 my Mercury 280's and then 300xs had no issues on current ethanol fuels. Since then my boat only needs 87. That's my opinion! BTW... there are some land gas stations selling 90 ethanol free octane for $4.60 last season.
Actually, I do know how to Tune an engine,however I am now 73 years old, I never rebuilt the carburetor and the 90 octane is the only fuel available with no ethanol. I do not know the compression ratio and since I have only run the boat once I did not notice the boost however the mechanic that built the motor said that the boost was right on. So what do you think of the $1150 cost?
I remember back in 92 was crucial to run no less than 90/91 octane per merc. I believe it was because it was early on and they loosened up a bit with 525 SC. And yes they did run pig rich set up from the factory.
The 575SCi was 91 Octane required by Merc.
If you do have a mechanic do your work be sure tell him you would like to have the parts that were replaced. Sounds like your basic maintenance. Did he do a leak down? Would suck if you got it back with same issues. Might be time to replace items mentioned regardless but I'd like to get a grip on what exactly is the problem. You can check the plug wires with an ohm meter. Can easily remove cap and clean it up and check for a crack. I just hate when a mechanic will say it needs all this and that and after all said and done your still back to square one. You can inspect plug wire easily look for any arcing. Nice to do at night as you can see arcing very quickly. My best guess would be timing or carburetor,. It least your moving forward anyway. To bad you don't have a twin brother to this one and starting parts one at time.
Just an opinion from a guy using e85 for about 10 years.
Varnish...but still smells like reasonable gas...I was totally shocked...I was expecting skunky old gas smell.
Aluminum tanks were 100% perfect. Try that 10 10% ethanol now...!!!
It is possible to anodize the inside of the tank to run ethanol fuels...just gotta find the right shop to do it.
