Looking for replacement 32 89730 >
Old 04-06-2020 | 09:26 AM
Mark do you guys also sharpen the hose clamps with an angle grinder like everyone else.. Just kidding. Seeing all those clamps reminds me of how I get cut by them every time I do work on the motor or bilge...lol...
Chris
Blueabyss is offline
Old 04-06-2020 | 09:30 AM
Originally Posted by Mbam
O - now I see. It wouldn't hurt to pull the fitting and have someone machine a section to give you a lip. We do that all the time when we make fittings.
I will probably.
F14A water jet is offline
Old 04-06-2020 | 09:33 AM
Chris
Agreed! I look for "rolled edge" replacement clamps and try to keep rubber clamp tips installed.
https://www.ebay.ca/itm/Worm-gear-ho...-/173540877932
Old 04-06-2020 | 10:00 AM
On some clamps i just put a blob of silicone. Works pretty good, stays on.
Got a 2" long "cat scratch" from working on the motor yesterday. Haha.
Cap'm Kurt is offline
Old 08-31-2020 | 09:01 PM
Resurrecting and old thread...the same (starboard, outboard) cooling hose (starboard thermostat to exhaust manifold) popped off again today during a speed run.
I tried double hose clamps, but I believe that I really do not have enough pipe to get the second hose clamp to bite (So it probably put additional pressure on the one "good" hose clamp.
This time, I roughed up the metal with sandpaper and the used Permatex Black Gasket sealer and a hose clamp.
I am surprised that (with all these ~28 hose clamps on two motors) only this one seems to be giving me issues???
Does anyone have a link to a wider/stronger/upgrade for this hose clamp?
Old 09-02-2020 | 10:05 AM
Anybody using/recommend these for more clamping force?
https://www.mscdirect.com/product/details/48499065
Old 09-03-2020 | 11:00 AM
It looks like somebody possibly welded an an extension onto the end of that T. They normally have a lip on the end. I would have somebody weld a small ridge on the end
Griff is offline
Old 09-03-2020 | 11:12 AM
F-2 Speedy's Avatar
What kind of water pressure are you running ? to blow hoses off
F-2 Speedy is offline
Old 09-03-2020 | 02:37 PM
The picture is not of mine exactly but is a pretty good representative of what I have...I will consider this action. Thanks!
Old 09-03-2020 | 02:40 PM
I do not know (no gauge, but I probably should have one) BUT two engines, two exhaust manifolds per motor and only this one has blown off...so I am thinking there is something unique/different about this side of the starboard engine.
