How to test float switch Lovett 1200
Depends on how its wired
First uses 2 fuses, and second only one
Could also be a bad connection going to the float switch or float is hung inside the box
If you don't have a high water alarm just ignore it in pic
Great information and help! I found a popped circuit breaker (engine electrical sub-panel) under the back bench seat (near Perko switch). Reset breaker, ran a garden hose to the bilge...pump performed as designed/expected and no popped breaker. :-)
